Long term Storage
Old Jun 11, 2019 | 04:12 PM
ryguycarguy's Avatar
ryguycarguy
Stage II
Default Long term Storage
Hello guys!
I have a 1200 2002 XL that has been sitting without being started for the better part of 9 years! It has a couple issues that I'll be posting later but as of now I noticed there's no or no visible oil in the bike when i parked it it was full or close to.
Any ideas where the oil could be and what would i do before firing this thing up?
I was thinking obviously changing the oil or whats left of it, putting some seafoam in the gas to break up the old gas and maybe oil or a shot of seafoam in the cylinder in case the piston is seized?
Thanks
Old Jun 11, 2019 | 04:49 PM
apache snow's Avatar
apache snow
The oil leaked from the oil tank down in the case. Don't add oil as it will be way over full. They all do that when left sitting. When started it pumps back into the oil tank.
Old Jun 11, 2019 | 04:59 PM
FreedomRider's Avatar
FreedomRider
pull the spark plugs and crank it over a few times … the oil should return to the tank
Old Jun 11, 2019 | 05:07 PM
ryguycarguy
Stage II
Thanks, would it be a good idea to run it before changing the oil or drain it as it sits?
Old Jun 11, 2019 | 05:43 PM
FreedomRider
you need to get the oil back into the tank before you can drain it … once the oil is back into the tank you can install the spark plugs and run it a little to get the oil warm … it drains easier when warm …
As-21
EVO
15
Apr 3, 2019 05:58 PM
Chris Sigo
Shovelhead
Dec 1, 2017 05:56 PM
dandanny81
Jul 29, 2012 12:18 PM
br401k
Mar 20, 2011 12:16 AM
dcdr
Oil Archive (no new posts)
Mar 12, 2010 03:58 PM
