Checking the jet size
Old Jul 11, 2007 | 02:29 AM
nickdv9's Avatar
nickdv9
Default Checking the jet size
Is it possible to determine what jets my carb has without removing the carb itself? Can I take the float bowl off and see? Minimal disassembly is the goal here. Thanks in advance!
Old Jul 11, 2007 | 03:07 AM
jwb47's Avatar
jwb47
Default RE: Checking the jet size
I serriously doubt it.
Old Jul 11, 2007 | 06:14 AM
cHarley's Avatar
cHarley
I've read of a few people here who said they did it but it would take just the right lighting and a magnifying insperction mirror. I had trouble reading mine even after I had them out in my hands with a magnifier glass.
If you are looking to stage 1 rejet on an 04 - 06 model, you could buy#45, #175 & #180 jets and probably have a 90% chance of having what you will need. They are only about $3 each.
Old Jul 11, 2007 | 08:59 AM
SportyPig's Avatar
SportyPig
I've read claims of people doing a complete re-jet without removing the carb. And I suppose it's possible. In my case, there is no way I could accomplish that. Eyesite isn't good enough, fingers aren't that nimble, etc etc. Removing the carb really isn't very difficult.
Old Jul 11, 2007 | 09:22 AM
128auto's Avatar
128auto
Yes, you can do that. Drain the fuel, remove the float bowl, use a mechanic mirror, you should be able to see the numbers stamped on the surface of each jet, you do not have to remove the carb to see the jet size.
Old Jul 11, 2007 | 03:29 PM
cHarley's Avatar
cHarley
After doing it the first time, I can rejet mine now in about 20mins including removing and replacing the A/C, without removing the carb. The carb does have to be loosened the first time to remove the mixture screw plug if your bike has one. If the bowl screws haven't been replaced with SS hexhead allen screws you will want to do that when you reinstall the bowl.
Old Jul 11, 2007 | 10:01 PM
nickdv9's Avatar
nickdv9
Thanks for the input fellas. I want to check because I bought it used, and while I assume it's jetted properly (SE slip ons and K&N filter) for stage 1, I feel like its running lean. I'm getting some blueing on the rear pipe, it pings when under high torque and the temp is above 190 degrees, among other things. I don't have a big problem taking the carb off but would like to avoid it if possible. I don't want to monkey with the throttle cables, either. Thanks again!
PS - '97 1200S
883Frankenbike
Nov 18, 2012 10:17 AM
glennt7
Aug 13, 2010 10:15 PM
artz
Sep 19, 2007 11:18 PM
deuce31
Exhaust System Topics
Apr 4, 2006 12:22 AM
HDF Tech
Carburetor Related
Jun 25, 2005 05:37 PM
