Fork upgrade question.
so fine, Ill fit a pair of longer damper tubes from the standard, roadster model from 2008. (The roadster for 2009 is totally different having inverted forks)
now, looking on the Jersey HD site, the main tubes for the 2009 Low, and the 2008R, have different part numbers!
I dont think the length varies, so I wonder what the difference is. Anybody know? Can I just fit the longer damper tubes, and maybe springs to suit?
so fine, I’ll fit a pair of longer damper tubes from the standard, roadster model from 2008. (The roadster for 2009 is totally different having inverted forks)
I don’t think the length varies, so I wonder what the difference is. Anybody know? Can I just fit the longer damper tubes, and maybe springs to suit?
The right sliders are different because the L doesn't have right-side calipers. The R has dual front brakes remember?
Just change your damper tubes and get the ones for the 2008 R and you'll be fine.
So, if I decide to get a longer damper for my forks, would it be wise to also get a longer top tube/stanchion as well?
Who has actually replaced the dampers with longer ones?
Before you spend any money, let me tell you my story. I have a 2011 SuperLow, owned from new. What I soon discovered was that my forks sagged more than 50% travel, with me seated on it. My stock shocks were also pretty shocking, despite being new. It was easy to buy new shocks. I chose normal Hagons, but if doing it again would buy their Nitro model, with the hope of a yet better quality ride. They recommend a longer shock, which lifted the rear around an inch.
Turning back to the forks, I replaced the springs with single-rate Race Tech and set the sag correct, which lifted the front just under an inch. My bike sits level once more, with much better suspension travel at both ends. I also installed Race Tech Emulators, but can't recommend them, as they don't seem to add any benefit. I have however used Ricor Intiminators in another bike, which I can recommend.
So those are two things to consider. The suggestion above for longer tubes and dampers is also valid, just a bit more expensive IMHO. I suggest you investigate your fork travel and sag first.
