trouble starting after Ultima ignition module
Old Jul 30, 2019 | 09:41 PM
karljohn's Avatar
karljohn
Stage III
Default trouble starting after Ultima ignition module
hey everyone, after having some symptoms of backfires and hard starting + a 20 year old bike i was led to believe i was in need a new ignition module. I ordered an ignition module from Tatro Machine and what i received was an Ultima Single fire ignition system. I took out my old module, hooked up the new coil and wired the new module directly to the coil. i used the diagram provided to me for single fire and did my static timing.
I also installed a Pingel hi flow petcock with a new fuel line that is slightly bigger than my old fuel line. I did not wire the Voes.
the bike will try to start, and i have a boom that sounds like a canon or a gun shot coming from it and a blue flame out of the front exhaust. the boom has been happening since before i replaced the module.
any ideas what might be happening? i messed with the tuning screw under the carb a little before the new install and the idle screw from the low idle and dying i was experiencing before i did the swap.
any information is greatly appreciated
LDR
Aug 3, 2019 12:00 PM
Crimson King
Feb 19, 2017 06:05 PM
hdbeggs
Feb 21, 2011 07:29 PM
badinfluence63
Aug 8, 2008 10:07 AM
badinfluence63
Aug 8, 2008 09:01 AM
