O2 sensor stuck
Old Aug 15, 2019 | 02:49 PM
Rise_'s Avatar
Rise_
Default O2 sensor stuck
So my o2 sensor is stuck to an adapter, it didn't fit in the exhaust I installed so it came with an adapter for it but now that I too it off it came out with the adapter and can't get it off. Any suggestions on how I can't remove it?
Old Aug 15, 2019 | 06:03 PM
Fightinggoat's Avatar
Fightinggoat
Try reinstalling the sensor and adapter, start the bike and ride it till the exhaust is good and hot, then remove it, usually a little heat gets things to loosen up.
if you have a torch, you could heat the adapter and remove it that way as well.
It can’t be stuck if it’s a liquid
Old Aug 15, 2019 | 07:58 PM
sorensentyler's Avatar
sorensentyler
Put it in a vise and turn out the sensor. Obviously don’t destroy the threads of the adapter unless you have another.
Old Aug 16, 2019 | 03:12 AM
Rise_'s Avatar
Rise_
Well i tried wd40, a torch, heating it on the exhaust and the thing is just stuck in there. Got frustrated and used too much force and broke it lol, well there goes 50 bucks down the drain idk why it was stuck so hard since it had only been there for a couple hundred miles but oh well. Thanks for the suggestions .
Old Aug 16, 2019 | 06:54 AM
MCSarge's Avatar
MCSarge
When you install the new one use anti seize on the threads and it will come out easier next time.
Old Aug 16, 2019 | 10:29 PM
Rise_'s Avatar
Rise_
Will do, thanks.
Old Jun 18, 2020 | 11:58 PM
JayEss's Avatar
JayEss
Old Jun 19, 2020 | 03:51 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
On the O2 sensor not adaptor else it will come out as one piece again.
You could try putting flats on the round disc for holding in a vice if it happens again.
crusader1xxx
Apr 27, 2018 09:48 PM
gtwalker1969
Apr 13, 2018 08:13 AM
gottah8me
May 2, 2017 08:37 PM
WideGlideFever
Jan 29, 2013 08:22 PM
jimmyg61400
Exhaust System Topics
Mar 22, 2012 03:54 PM
