Can't get the speed right in traffic .
Old Oct 8, 2019 | 12:45 PM
  #41
Midpegs's Avatar
Midpegs
Originally Posted by John Harper
You may have to get a proper needle, emulsion tube and Keihin mainjet if you go back to stock slide. Or, if you have Dynojet needle, just swap over to the new slide. The Dynojet needle, emulsion tube, and mainjet are not the same as the stock carburetor. Pilot jets are the same. There is a different thread size for the Dynojet mainjet in the emulsion tube.
John
This is very constructive advice . When I got the bike I got no first hand information about exactly what carb mods had been done . I have a receipt from an HD dealership for a 180 main and a 45 pilot and an instruction sheet from a Thunder Slide kit . I've had the carb apart and the needle looks stock compared to other Dynojet needles I've seen . The slide just looks stock . I've got V&H Straightshots with standard baffles and a K&N in a stock airbox . It's nearly winter here now so I've got plenty of time to figure out what's with this carb . I'm also thinking that the emulsion tube might be involved somewhere . These are some of the disadvantages of buying second hand but it was the best Harley I could afford.
Old Oct 8, 2019 | 12:58 PM
  #42
John Harper's Avatar
John Harper
I you have a Keihin 180 mainjet in the carb, there is not a Dynojet emulsion tube in there. Different thread sizes.
John
Old Oct 8, 2019 | 01:35 PM
  #43
Midpegs's Avatar
Midpegs
John
Thanks , that's something for me to check . I guess it could be worn . Emulsion tubes can become slightly oval without this being visible to the naked eye and I guess this might cause a jerky transition from pilot to main .
Old Oct 8, 2019 | 01:42 PM
  #44
Midpegs's Avatar
Midpegs
Originally Posted by Madnss
how dare I give my opinion lmao
I would be very grateful for your opinion . You clearly have a wealth of knowledge especially regarding tuning . It's the straight for the throat insults I can do without thank you very much .
Old Oct 8, 2019 | 08:10 PM
  #45
Long lonesome highwayman's Avatar
Originally Posted by Midpegs
Does anyone else feel this way about their Sportster ? I love my bike , it accelerates well , it slows down well and it gets down the road in a most pleasing fashion . On the open road I can ride all day long with a stupid grin on my face . BUT there is one thing that my bike just won't do and that's to exactly match and maintain the speed of another vehicle . If I'm stuck in moving traffic or behind a car on a narrow road , my bike just doesn't seem to know whether it's speeding up or slowing down . I try experimenting with different gears but in the end I find myself slipping the clutch in order to perfectly match the speed of the vehicle in front . How you guys manage to ride in groups is a mystery to me . Years ago I rode a couple of TL 1000's and it was exactly the same . I could accelerate like a rocket and stand the thing on its nose but try to behave myself in traffic and it was all over the place . So is this just a big V Twin thing or is there anything I can do to fine tune my bike ? I've got a carb version ( XL 1200 R ) which allegedly has a " Thunder Slide " in it . Any views most welcome .
Mines a 98 1200 custom with a carb and I've never had a problem matching the speed of a vehicle in front of me. In fact I was on a group ride once when I was, (like everyone else in the group) riding very close to the mc in front of me and side by side to another mc. on the interstate. It's not the way I would've preferred to ride after they let me in the group things just closed up to the pattern they had been doing before I came in from the on ramp. I was invited to join the group at that location.
It sounds like you have an issue either with your technique or the mc. If you're able to maintain a speed on level ground with another similar Sportster, there's something wrong with your mc. I guess.
Old Oct 9, 2019 | 05:25 AM
  #46
Originally Posted by lewk
OP, it seems you have the international version of the XL1200R, so your transmission pulley is a 30T sprocket (PN 40380-04). That means your bike is higher geared than the US version that most of your critics here ride.
I have that same PN and when going 15mph or slower, I HAVE to be in 1st and I'm always using the clutch. I go into 2nd gear at around 25 until well past 30mph.
I'm fine and you'll be fine too. With our gearing, highway riding is a blast as you undoubtedly already found out.
So. Ignore the naysayers here. Some of them are talking outta their obamas (and I don't mean brains).
Too true.
That
I also have the international gearing, but I don't have a problem keeping a steady speed. I didn't however think the OP meant very slow speeds though, but typical down the road city speeds or higher. Since going with that gearing I can ride on the interstate if I need to and still be able to see what's in the side mirrors.
No not really , what I'm talking about is trying to maintain an exact speed of say for example 40 miles an hour . Not 41 and not 39 , exactly 40 . The bike is doing one of two things , speeding up or slowing down . What it does not want to do is remain at a constant speed . Of course the obvious thing to do is yank on the throttle and overtake the slow vehicle but that is not always a safe option on the minor roads of rural Warwickshire , Oxfordshire and Wiltshire where I do a lot of my riding . At higher speeds on the open highway such as 70,80, 90 or even a hundred + the bike is brilliant and will hold a constant steady speed without issues . It's just that middle ground where you are having to restrict the bikes natural eagerness to accelerate that feels so uncomfortable .
40 mph or 40 kph? (which is around 24 mph) If kph it might be a gear selection issue. Either way I'm leaning toward it being a technical or mechanical issue with the mc. Unfortunately I don't know exactly what. I am curious as to what you find out is the culprit, so if it happens to me I'll know what the issue might be.
Grizzwood
Apr 4, 2015 02:02 AM
streeteagle
Sep 12, 2013 04:46 PM
paguy
Jun 14, 2010 10:10 PM
PoCoBob
May 15, 2007 11:42 AM
MikeyBad
Oct 27, 2005 12:36 AM
