Old Dec 27, 2019 | 07:27 AM
Dmd3's Avatar
Dmd3
Stage II
Default 883
Popping coming from Mikuni carb+excessive gas in air filter any suggestions?
Old Dec 27, 2019 | 11:09 AM
cacomly's Avatar
cacomly
What will help is if you list anything that you may have changed recently.
Old Dec 27, 2019 | 08:32 PM
Dmd3's Avatar
Dmd3
Stage II
Not a thing,its cold here in Cleveland so ive adjusted the idle after the 10 mins.it takes to warm up
Old Dec 27, 2019 | 09:58 PM
Madnss's Avatar
Madnss
Rather than assume and attempt to help you via text. I’ll drop this here. It’s easy to read, comprehend and a must for new and seasoned mikuni users. Good luck!
fyi: don’t let anyone tell you that 42 mik is too big for an 883, it can be tuned for it. I ran a 48 mikuni on a bone stock 883 just to prove a point.
https://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
Old Dec 28, 2019 | 06:58 AM
Midpegs's Avatar
Midpegs
Invest in an extended pilot air screw that can be tweaked by hand when you're out on a run .Same goes for the idle adjuster . Much easier than trying to use a screwdriver on an engine that's jumping around .
Flar
Dec 30, 2019 07:12 PM
STREAK
Good Or Bad Shopping Experiences At HDF
Mar 25, 2014 07:33 AM
barrygreen
Sportster Parts
Dec 27, 2013 02:21 PM
todevski
Mar 13, 2012 02:23 PM
JKP883
Exhaust System Topics
Aug 10, 2008 11:51 AM
