Kickstand Education
Old Dec 31, 2019 | 03:22 PM
Midpegs's Avatar
Midpegs
Well if nobody understands the issue and the OP has yet to respond to requests for clarification , I fail to see the point in further discussion . Happy New Year .
Old Dec 31, 2019 | 07:27 PM
dave the welder's Avatar
dave the welder
Just checked my sportster, It dosent have a kickstand. It has a jiffy stand...
Old Dec 31, 2019 | 09:34 PM
boomerguy's Avatar
boomerguy
Bushings wear out on the jiffy stand. Easy fix: Colony OEM and Custom Hardware Jiffy Stand Mount Kit #3134-4
If the bike leans over too far like my 2005 XL883 does with new tires that are taller (nominal OEM size, but still taller). Easy fix: Bung King CNC Aluminum Kickstand Lift Block
There is no re-engineering or modifications involved.
Old Jan 1, 2020 | 03:12 AM
Midpegs's Avatar
Midpegs
This is not the first time the OP has initiated a discussion about kickstands . Last year ( 2018 ) the overwhelming consensus was that there is nothing wrong with the design and presumably nothing has changed since then . As previously mentioned , some better information and a few pictures of exactly what the issue is would be greatly appreciated .
Old Jan 1, 2020 | 07:56 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
One thing to be aware of is how the stand works to lock in place. The frame has triangle for the stand to pivot around. If you don't do anything and even if you do the paint is gone from that part of the frame and will now be going rusty. How long it will take before it becomes an actual problem I have no clue. Since I had my stand off to cure a stand down interlock switch issue I was able to put a coat of grease on it and the back side of the stand and all the other moving parts.
It is easy to see once the parts are off the bike how it can all seize up making it look like a spring problem.
Old Jan 1, 2020 | 08:17 AM
boomerguy's Avatar
boomerguy
The spring usually lasts an extremely long time but they can be purchased separately from the same seller as the bushing kit. I bought an extra spring - just in case - and didn't need to use it. Replacing the bushings is easy.
The spring however, takes a certain procedure with simple garage tools to uninstall/reinstall because it is extremely strong. Here is how I replaced the spring:To remove or install the kickstand (Jiffy stand) spring on a Sportster, the easiest method is to place the motorcycle on a jack to provide complete movement of the kickstand.
To remove the kickstand spring, raise it as far as possible to allow it to shorten and relax. First, remove the rubber bumper so it can travel farther and then hold it in place with one hand against the frame while using Channel Lock slip-joint pliers to slide the spring hook off the motorcycle frame “button”.
To install the kickstand spring, you will need to temporarily extend it farther than normal by inserting washers (used aluminum crush washers work best) into the gaps in the spring loops. To extend the spring and open the gaps, place one end of the spring into a loop in the bench vise. Then use another steel loop for the other hook and slide a long pry bar through the loop. Place the bottom of the pry bar against the base of the workbench below the below the bench vise and pull down, extending the spring so the gaps will open. While the spring is extended, insert 10 crush washers into the gaps in the spring loops. Now the spring is longer than normal.
Take the extended spring to the kickstand and attach one hook around the frame “button” and insert the other hook into the kickstand hole. Lower the kickstand to stretch the spring and open the gaps, then remove the washers with pliers with a 90-degree nose by sticking the nose into the hole of each one and twisting the washer out of the gap.
Old Jan 1, 2020 | 08:31 AM
Andy from Sandy
All I did was put the spring on and then lever the stand back into place. Once in position I was able to put the pin and bushes back in.
Old Jan 1, 2020 | 08:42 AM
boomerguy's Avatar
boomerguy
I wish mine had been that easy. That's why I didn't replace it, it was so strong. The only way I could open the spring so I could insert the washers was to use a pry bar against the workbench as a fulcrum. Just pulling on it did not work. My new spring is still in my parts box. My bushings however, were very worn and the jiffy stand had a lot of "slop". The bushings are obviously sacrificial to keep the body parts from wearing. Great design for a locking mechanism, even if it is over 100 years old.
Old Jan 1, 2020 | 11:09 AM
Midpegs's Avatar
Midpegs
Yep , exactly how I have always fitted side stands even when I've upgraded the springs or I couldn't find one that was long enough . Connect the spring and use the leverage of the stand to pull it round into place and drop the pin in . I'm utterly baffled by people who fart around inserting washers or coins into the spring but if it makes them happy then fair enough .
Old Jan 1, 2020 | 12:14 PM
boomerguy's Avatar
boomerguy
That was the first thing I tried because it seemed the obvious choice. I couldn't get it to work, no matter how hard I tried. Mine is a 2005 if that makes a difference. I definitely didn't want to "go the long way around" like I did. Guess I'm just jiffy stand challenged.
