Rocker Box Gaskets. . .
Place cover on a pane of glass and use feeler guages to find the high spot.
Invert cover and mark high spot w/Dykem or Magic Marker.
Obtain an 8 inch coarse/ fine sharpening stone and start w/ coarse side.
Have a chair or shop stool and sit, cause this may take awhile.
Put the cover in your lap and the stone on the opposite side of the high spot.
With moderate pressure slide the stone back and forth while moving it completely across the cover.
Rotate cover 90 degrees and repeat.
Do this until you are back where you started, and keep doing it till the markings start to disappear.
Then use the fine side once or twice and check w/ feeler guages. I used a .002 guage.
When feeler guage won't fit under cover, your done.
Clean surfaces and reinstall.
Took me about an hour to flatten cover this way. I did use brake kleen to clean the stone every complete rotation,cause the aluminium will clog stone.
The other choice I had was take cover to machine shop and hope they could do it w/o removing to much metal.
Hope this helps.
There is no way any of the bolts were loose as it has not been touched from the factory.
What has to be done though is the new gasket has to be fitted in such a way that no of the bolts make contact with it to deform it. I did it wrong and it leaked within a few miles. I took it to the indy and it was job done in really just a few minutes.
- G
- G
John
