Help getting exhaust pipe off!
Old Apr 12, 2020 | 05:48 AM
Rook83's Avatar
Rook83
@Andy from Sandy @grbrown
Thanks for the info guys...I think I'm just going to buy a 10mm Allen Wrench...I don't think I needed to try to take the exhaust off...do y'all think that's a good idea? This is just to take the brake/peg off...let me know!
Old Apr 12, 2020 | 05:57 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Which allen screw do you think is 10mm and do you mean a hex driver? The bracket that bolts to the frame to hold the footpeg and brake peddle is not metric.
Old Apr 12, 2020 | 05:59 AM
Rook83's Avatar
Rook83
Sorry, I meant hex...the 10mm is very snug in there, but I'm back in the house...its 6AM here so I don't want to be clanking outside haha.
Old Apr 12, 2020 | 06:08 AM
grbrown's Avatar
grbrown
10mm and 3/8" are quite close in size, 10mm being around .018" larger.
Old Apr 12, 2020 | 06:10 AM
Andy from Sandy
There are occasions when metric and SAE line up such that they do work interchangeably but on a stock bike those bolts are not metric.
Are you just starting to guess what you need to do or do you have some mechanical knowledge to not damage your bike?
Old Apr 12, 2020 | 06:11 AM
Midpegs's Avatar
Midpegs
If you grind about half an inch off the appropriate Allen Key it gives you enough clearance to remove or fit Mid Controls without disturbing the front exhaust down pipe ( Header ) But it sounds like it's a bit late for that .
Rook83's Avatar
Rook83
I've worked on cars quite a bit...bikes are a different story...
Old Apr 12, 2020 | 06:19 AM
Rook83's Avatar
Rook83
Thanks for the info! I'll try both methods...with the allen key and if that doesn't work, taking the whole darn exhaust off. I have one more day off before work so I will get it done today!
Old Apr 12, 2020 | 07:07 AM
Rook83's Avatar
Rook83
Good God I got it done...I’ve never felt so weak! Had to get some super grip airplane mechanics gloves my dad gave me...thanks to all!
Old Apr 12, 2020 | 07:15 AM
grbrown's Avatar
grbrown
Thumbs up
Brilliant news - well done!
