fork oil drain problem
Old Jul 21, 2007 | 03:05 PM
fob_speicher's Avatar
fob_speicher
Default fork oil drain problem
Anyone have problems draining a fork? I started replacing my fork oil and the first one went well. I get the second fork and nothing came out - I thought it was dry but I only added about 5 ounces then it started over flowing....I capped off the spring and removed the drain screw again but nothing comes out still. Also, does a 1200 custom have a dry or wet fork? The book says to add 9 to 10.2 ozs of fluid depending on the fork type...I started with 9ozs.
Old Jul 21, 2007 | 03:26 PM
HOTLAP's Avatar
HOTLAP
Default RE: fork oil drain problem
Try gently poking in the drain hole with a tooth pic or something to see if it is just blocked, maybe a bit of plastic or paper got in there when it was built or the last time the fluid was changed.
Old Jul 21, 2007 | 04:15 PM
rbcss's Avatar
rbcss
ORIGINAL: HOTLAP
I heard of someone with a similar problem. the factory never finished drilling through the fork
Old Jul 21, 2007 | 05:12 PM
Tommo's Avatar
Tommo
What models have adjustable front forks apart from 1200 sport's...do these work on air and not oil?
Old Jul 21, 2007 | 07:30 PM
fob_speicher
I poked around with a toothpick but it wasn't going in very far so I took a small allen wrench and poked some more then the fluid started coming out. I'm not sure if it was aluminum flashing blocking the hole but it was definitely clogged.
Helli
Apr 8, 2017 08:30 PM
Ezridr60
Sep 6, 2014 08:02 PM
Roni
Mar 3, 2013 10:16 PM
keith t
Jun 7, 2012 02:07 PM
harley_jeff
Jul 25, 2010 10:52 PM
