Does anyone have installed this handlebar (PN 55800103) on a 2010 XL1200N sportster nightster?
I did some research but still don't know for sure if stock brake and clutch lines will fit.
In two Harley dealers said that would fit but I wanted to be sure first in case anyone installed these already.
I am having my doubts with the brake line since it has like a metal angle. PN 55800103
I haven't installed them but HD does offer a Handlebar Installation guide that does list that part number and includes cable and wire extension part numbers needed-
Maybe that can help you.
I'm sure my fears are unfounded but I couldn't bring myself to ride with a handlebar that has four welds in it . And particularly one without any gussets .
Hello @shanneba
I saw this document, but maybe I am not understanding it. For example, in the "stock" column, it only mentions extensions for the switch and turn signals. But if you see where it says brake, it says "n/a" and for clutch and throttle cables I understand that stock wires fit for everuthing except switch and turn signals?
