Simple Preload Question
Old Jul 28, 2007 | 04:57 AM
anewharley's Avatar
anewharley
Default Simple Preload Question
First bike, so please bear with me (2005 XL1200C)
I just want to make sure I understand correctly: In setting the preload on my bike, the minimum setting should be used if the rider is lighter weight/no passenger, etc. and maximum should be used for the most weight/with passenger, etc., right??
Also, I weigh around 175 and ride solo most of the time; what do you guys think I should set the preload to initially (any input for those in the same category would help). Thanks all!
Old Jul 28, 2007 | 07:25 AM
ryback's Avatar
ryback
Default RE: Simple Preload Question
Based on your weight, you probably want to use the 2nd or 3rd notch, depending on how firm a ride you want.
Old Jul 29, 2007 | 05:49 AM
XL1200C07's Avatar
XL1200C07
NewHarley - I agree rybakc, 2 or 3 will likely be best. You should try all five positions and see which one you like best. If you don't have the spanner wrench, they only cost a couple of bucks and it's real easy to change the preload. One thing that I've noticed is the 20+ pounds of additional weight you pick up by filling the gas tank makes a significant difference.What works best for me is to set the preload when I have a full tank of gas.
Yousay you ride solo "most of the time" - make sure you add more preload when you have a passenger. My wife and I together weigh about 375 lbs (mostly me!) - on the factory default first/lightest setting, the bike really wallows around and is very difficult to control. On the maximum/fifth setting, the bike seems more comfortable and stable than when I ride solo. With the extra weight of a passenger, the preload setting seems to have a big influence on how the weight gets shifted to the front tire when you brake.
Ride safe and have fun!
LoneRiderFLH
Jul 1, 2017 12:39 PM
Ash16
Oct 18, 2010 07:21 PM
Strongarms
Aug 24, 2008 02:08 AM
bigtop
Jul 17, 2006 12:44 PM
