Points issue
Old Jan 19, 2021 | 09:04 AM
RPRocker1320's Avatar
RPRocker1320
2nd Gear
Default Points issue
IMy Freind has a 99 Sportster he has put points ignition in it. , When you tighten the bolt to the mechanical advance it loses all spark. you can loosen it and spark returns. when it is tight the advance works as it should. Any thoughts? I'm stumped.
Old Jan 19, 2021 | 09:43 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Interesting. The advance unit is indexed on the cam with a shear pin and the advance unit bolt screws into the cam to hold it in place. When it's tight the advance unit works properly like it's designed to do. I would have to say that the lack of spark has nothing to do with that bolt being loosened up. Redo the points gap and follow the Factory Service Manual for the procedure.
Old Jan 19, 2021 | 09:49 AM
RANGER73's Avatar
RANGER73
If you're losing spark you're losing the ground. as that's what the signal is sending to the coil.
You're probably bending it out of line or proper gap when you tighten it.
brett.
Jan 25, 2024 06:58 AM
RobertKing
Ironhead
Apr 6, 2017 07:02 AM
tugboatlife
May 19, 2014 06:31 PM
BobBar
May 16, 2011 11:59 AM
smithjs10
May 12, 2008 02:00 PM
