Motobatt battery
Old Apr 7, 2021 | 12:29 PM
apache snow's Avatar
apache snow
Default Motobatt battery
Any one using a Motobatt Battery MBYZ16 HD. If so what did you think of it. Thanks.
Old Apr 7, 2021 | 01:08 PM
Midpegs's Avatar
Midpegs
Ha ! 😂 I've just taken delivery of one about an hour ago so I'm not quite in a position to pass judgement just yet . Ask me in six years time .
Old Apr 7, 2021 | 06:28 PM
apache snow
Mine will be here Friday. Its replacing a Yuasa. Hope its a good one. Yeah, that reminds me, I've got some front brake pads to put on. Need to flush the system as well.
Old Apr 10, 2021 | 06:55 AM
ChrisOfTheOT's Avatar
ChrisOfTheOT
Afternoon Apache - I don't have that number but this one (MBTX12U):
Nice and yellow innit? I'm not impressed as it struggles to start my Sporty (but so did the H-D battery). Also, if I don't keep it hooked up to the solar charger, it cannot hold charge after a year. Mine was cheap, so there is that... It's the second one I've had and I'm still using the one I got about 18 months ago 'cos the solar charger keeps it working: so far, so good. But it's not got the 'cold cranking amps' I'd like.
But, cheap is cheap!
Cheers,
Chris
Old Apr 10, 2021 | 07:52 AM
Midpegs's Avatar
Midpegs
Cheers,
Chris
That's the one I've just taken out ( came with the bike ) . It always struggled to crank the engine but the bike never actually failed to start . The fact that it sits on a plastic tray to make it bigger should tell you all you need to know . It might be better in an 883 .
Old Apr 10, 2021 | 08:40 AM
apache snow
I put mine in yesterday. It is 240 CCA the same as the Yuasa GYZ16HL. The Yuasa did a good job till this year. It would start the bike but really slow. It was going on 5 years old. The Motobatt starts my bike fine just like the Yuasa did when it was new. My bike is a 1250 with 10.5 to 1 compression so its harder to turn over than a stock bike. So far I'm happy with it if it will last as long as the Yuasa.
Old Apr 10, 2021 | 09:26 AM
ChrisOfTheOT
I put mine in yesterday. It is 240 CCA the same as the Yuasa GYZ16HL... My bike is a 1250 with 10.5 to 1 compression so its harder to turn over than a stock bike...
Oooooh, I like the sound of a 1250 bore kit. Bit jealous now... This CCA stuff was all new to me, but 240 sounds impressive. I assume the MBYZ range is bigger, better and more powerful than my MBTX so it sounds like you dun betterer than wot I did. If it starts a 1250 with high compression, you're on to a winner!
Cheers Apache,
Chris
Old Apr 10, 2021 | 09:29 AM
ChrisOfTheOT
Originally Posted by Midpegs
That's the one I've just taken out ( came with the bike ) . It always struggled to crank the engine but the bike never actually failed to start . The fact that it sits on a plastic tray to make it bigger should tell you all you need to know...
Yes Midpegs, the MBTX flavours do seem underpowered all round. Glad yours always started 'cos I've had many start failures - I've got a starter now, which helps.
Live and learn, etc.
Cheers,
Chris
Old Apr 10, 2021 | 09:39 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Has your bike got a siren and HD security system? Is it also keyless ignition? All of these things are a drain on any battery.
I am led to believe my 2017 with above features will draw enough current just sitting in the garage to flatten the stock battery in about 5 weeks (take enough out of it so that the engine will not start) unless kept on a tender charger.
Old Apr 10, 2021 | 10:56 AM
ChrisOfTheOT
Yes Andy, it's a 2016 XL1200CA - I believe the security system is the culprit too (no siren!), and keyless ignition. Note that in the Summer there is no problem in the first year, only the second Winter. I did look at expensive batteries (Ł230+), but they generally only had a 2-year guarantee. I figure a fifty quid battery every year was cheaper - so long as I keep the solar panel connected.
Cheers,
Chris
