Noise when accelerating
Old Jul 12, 2021 | 09:31 PM
RicketyCricket's Avatar
RicketyCricket
Stage II
Default Noise when accelerating
Hey there everybody!
New user to the Forum. Thanks for reading my post.
I have a '92 XLH. Recent complete rebuild to a 1200.
There is a "clacking" noise starting at 2500 (or so) RPM in every gear. It happens only when I apply throttle. Does not happen in neutral or when I pull in the clutch.
I thought it was something loose, like the tank, horn, etc. Everything external is as tight as can be.
If it's working hard, like going up a hill, the sound goes away but resumes when it levels out.
I'm at a complete loss.
I look forward to any help !!
Thanks
Old Jul 13, 2021 | 07:44 AM
davekp's Avatar
davekp
Timing?
Old Jul 13, 2021 | 08:09 AM
86glider's Avatar
86glider
Primary chain may be too loose?
Old Jul 13, 2021 | 09:38 AM
Midpegs's Avatar
Midpegs
I'm thinking along the same lines . Either a slack Primary Chain or a worn out tensioner shoe . Might be time to have the cover off for a look see .
The other thing that might cause this is some of the holes that the engine mounting bolts go through might have become elongated and the engine is being pulled back in the frame under load .
Old Jul 13, 2021 | 10:29 AM
Acrodave22's Avatar
Acrodave22
I had a similar noise in my 05 883L. It went away when I replaced the old plugs, which looked fine, with new Iridium ones......... Beats me as to why, but for $20, it's worth a try.
Old Jul 14, 2021 | 07:37 AM
heybaylor's Avatar
heybaylor
just rebuilt to 1200 ???, sound like spark knock .
what octane are u running ?
what is the compression ?
did you use the 883 heads or 1200 heads (there is a difference)
(on my 91 , I had to radius out my 883 heads to 1200 spec's,(way too much compression)
who punched out the motor ?
Old Jul 15, 2021 | 04:17 PM
RicketyCricket
Stage II
Default noise when accelerating
Thanks!
Well, I had the 883-1200 conversion done originally. Since the engine was rebuilt, it was done as a straight up 1200 with all 1200 parts.
I normally use 91 octane (just ask my wallet).
Unfortunately, I don't know the compression. I don't wrench myself so I'm at the mercy of others.
I'll investigate spark knock. It's not a ticking but a real "clack" that I always thought came from the primary.
Thanks again for your response!!
mtx1
May 7, 2019 04:53 PM
jbyun
Nov 7, 2018 04:50 PM
1blackz28
Apr 4, 2013 09:42 AM
jefnightrain
Jun 11, 2009 06:52 PM
forever young
Aug 31, 2008 09:05 PM
