Carb or ignition
Old Aug 6, 2007 | 08:44 PM
88stroker's Avatar
88stroker
Stage II
Default Carb or ignition
I have a 1988 sportster 1200 with a 1340 stroker kit cammed out. Im having a problem and have heard a couple different things. I tore the bike down to motor and frame this winter and put a new tank and fenders, clutch, and stator in it. I also had the carb rebuilt. When i put the new tank on i had to relocate the ignition. when i got the carb back it had stock jets back in it and the motor isnt close to stock. Before i messed with it i could rev it to about 3 grand then it would die like it was gettin robbed of fuel so i put the old main jet back in there. It helped outa little but it still cuts out like crazy.Ive talked to people and some think its the carb like me , some think its the ignition, and others think its the charging system. Im thinkin about buying a S&S E carb with intake and manifold but i want to get the problem fixed before i spend 400 bucks on the carb kit. If you have any ideas or suggestions i would really appreciate them. THANKS
[/align]
Old Aug 6, 2007 | 08:49 PM
Wolhar's Avatar
Wolhar
Default RE: Carb or ignition
I"ll offerwhat would simply be a guess without hearing or seeing the Bike. Sorry, wish I could help, about all I can say is, if it were electrical, I think it would be a constant problem, not one that is only at a certain point or rpm, however, like I said only a guess.
Old Aug 6, 2007 | 11:43 PM
1200c's Avatar
1200c
I think it's the spark plug wires or spark plugs. Check the simple stuff before you start spending big money on carbs and ignitions.
Dumd ass
Shovelhead
11
May 6, 2019 04:52 PM
dkfxr
EVO
Aug 28, 2011 11:36 AM
Fatbob8193064
Exhaust System Topics
Sep 9, 2008 06:17 AM
panicSG
Classic
11
Apr 21, 2008 02:07 AM
Beeracuda
Feb 19, 2007 01:38 PM
