Diagnostic Code b2113
Hello, new Harley owner here, Just bought a 2017 Iron 883 with 1,500 miles. Riding yesterday and when I started the bike, red security light stayed on. Got home and did some research and came up with the following diagnostic codes:
BCM b2113, b2121
SPDO b1211
I was able to clear all codes but the b2113 code. There are no accessories on the bike other than a previous owner installed second battery tender/accessory cable. I removed that just in case it was causing the issue but still same b2113 code and red light staying illuminated.
Any thoughts on this?
Thanks all.
ET
BCM b2113, b2121
SPDO b1211
Thanks all.
ET
B2113 ACC output shorted low
If you cannot clear B2113 then I would be checking the Accessory Power wire from the BCM.
Wiring diagram - 94000402pdf_en_us - 2017 Wiring Diagrams | Harley-Davidson SIP
Okie883custom
Oct 16, 2018 02:01 PM
