Front wheel options
Old Sep 7, 2021 | 05:51 PM
Quimo's Avatar
Quimo
3rd Gear
Default Front wheel options
Picked up a 2005 Sportster Custom. Doing some suspension and performance mods and wondering what options are out there for front wheels? Are most year hubs interchangeable?
It currently has the stock spoked 21” up front (which I actually like the look).
Old Sep 7, 2021 | 07:07 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The 39mm diameter Showa brand forks have been stock fitment on Sportster models since 1988, so in theory you could fit a front wheel from any Sportster model with 39mm forks since 1988 to a later model. However the front axle has changed in that time, so the bearings are a different size. 2000 to 2007 front axles are 3/4" diameter and 2008 to 2021 front axles are 25mm diameter.
So 2005 Sportster forks will accept a wheel from a 2000 to 2007 model.
2008 - up wheel will also require the metric axle and bearings.
Old Sep 7, 2021 | 07:16 PM
ballbreaker69's Avatar
ballbreaker69
Rocker 19 inch wheel [2008] with axle reducer bushings from 25mm-3/4 should fit,
Old Sep 8, 2021 | 08:58 AM
Quimo's Avatar
Quimo
3rd Gear
Thank you, very helpful!
Old Sep 8, 2021 | 09:15 AM
cvaria's Avatar
cvaria
you determine the expanse of your options. That bike is your "Field of Dreams".
You can fo whatever you want there. No matter what anyone here says... your only limits are your own present ingenuity and risk aversion. 100% Malleable .... nothing on that bike is permanent. Nothing. Have fun
Old Sep 8, 2021 | 02:10 PM
ballbreaker69
Copy that cvaria
ranran4
Wheels/Tires
Mar 20, 2018 05:03 PM
kingan936
Sep 28, 2017 10:36 AM
jlsnow72
Oct 15, 2015 10:40 PM
RC07ultra
Aug 19, 2015 05:36 PM
dietdewboy
Aug 15, 2007 01:47 AM
