I got a problem?
Old Sep 8, 2021 | 05:05 PM
Whos7hat's Avatar
Whos7hat
1st Gear
Default I got a problem?
Yesterday I was riding and had my motorcycle slip into neutral, could've been a mistake somehow on my part but I was in fourth gear which seems odd. Well I got to where I was going and jumped right into looking for the issue, figured it was low on 30w
​​​​​​And as I found out low was an understatement 😅
so I jumped in a friends truck and drove to the store and got Lucas 30w trans oil. And I also got this Lucas stuff you add for leaks or whatnot. Came in a white bottle with a cone cap blue lidWell honestly I don't know how much the primary case calls for, I think a quart or so? I put both bottles in. I know I overfilled, but on the way to the next town over me and a friend were riding to go do some work. He kept looking at his bike and thinking his bike was splashing something on his. Turns out it was mine. My bike had oil everywhere including. All up my back. Well I couldn't find any reason why it was spitting so much out and decided it's cool, it'll top itself off and I will be good. Then my bike stopped running and I had to trailer it home. It will run. But once I get up to speed it cuts out and dies
Old Sep 8, 2021 | 05:34 PM
MURPHCC1's Avatar
MURPHCC1
bring it to a certified mechanic.......(trailer it! dont ride it!!)
You obviously know nothing about bikes.
Old Sep 8, 2021 | 05:37 PM
kel03's Avatar
kel03
Where did you put the oil !
Old Sep 8, 2021 | 05:46 PM
WP50's Avatar
WP50
Are you adding trans fluid to a sportster ?
Least tell us what year.
WP
Old Sep 8, 2021 | 05:54 PM
Whos7hat's Avatar
Whos7hat
1st Gear
Okay you guys. I'm not a ****ing idiot. I don't have a certified mechanic in the town I live in, and I wouldnt take it there to have him put oil in the primary case. Which is where I filled it. And I know I put to much. But I didn't put in two quarts if that's what your thinking
one was a quart bottle of Lucas
And the other was like 710ml and I only put more in because I have a leak where the clutch line goes into the case from hitting a deer I figured someone could help me out here and not insult me.
Old Sep 8, 2021 | 05:56 PM
Whos7hat's Avatar
Whos7hat
1st Gear
Sorry guys, yes. It was empty when I pulled the plate off. It's a 98 1200
Old Sep 8, 2021 | 05:57 PM
MURPHCC1's Avatar
MURPHCC1
get yourself a Factory Service Manual
Old Sep 8, 2021 | 06:04 PM
MURPHCC1's Avatar
MURPHCC1
not too familiar with the sportsters..........do they have two separate compartments for trans and primary?
or are they bathed in the same oil?
Old Sep 8, 2021 | 06:34 PM
MURPHCC1's Avatar
MURPHCC1
"Okay you guys. I'm not a ****ing idiot."
You put two quarts(64oz) in where it's supposed to only take like 32oz is not the act of a prudent person!!
Old Sep 8, 2021 | 06:52 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The Sportster's primary chain case and the transmission are connected so they do share the same fluid.
The 1998 H-D Service Manual says that after draining the old fluid to add 32 fluid ounces (one quart) or (946 ml) of H-D Sport Transmission Fluid or an equivalent fluid.
