Starting issues
Old Jan 8, 2022 | 05:41 PM
TC99's Avatar
TC99
Stage I
Default Starting issues
New guy here. Have an issue I can't seem to figure out. Have a 99 1200 custom. Bike ran fine then when leaving work would not start. Replaced ignition coil and had no issues for about 3 weeks. Same problem occured. I have replaced electronic module for mechanical about 7 years ago. A friend suggested vacuum control module. Anyone have any thoughts that might help. Thanks brothers
Old Jan 8, 2022 | 07:55 PM
hammer6315's Avatar
hammer6315
I vote against the vacuum control module. Does the coil have to match the mechanical set-up?
Old Jan 8, 2022 | 09:20 PM
TexasScooterTrash's Avatar
TexasScooterTrash
The "Vacuum Control Module" is a Vacuum Operated Electrical Switch. All the VOES does is trigger the advance/retard of the electronic ignition. Electronic and mechanical ignitions use different coils. Such as 3 ohm for electronic and 5 ohm for breaker points. When is the last time you inspected the 7 year old conversion breaker points? Might wanna check for burned/pitted contacts and a bad condenser. PLEASE, do yourself a Big Favor. Get a HARLEY DAVIDSON FACTORY SERVICE MANUAL.
SG -KJ
Shovelhead
Mar 13, 2022 07:17 PM
ScreamingMetalDeathTrap
Mar 3, 2019 06:24 PM
Mar 2, 2019 08:37 AM
DragonArm
EVO
11
Aug 20, 2013 07:42 AM
CaptainHook
Jun 1, 2013 07:56 AM
