2019 vs 2020 Service Manual
Old Feb 7, 2022 | 10:28 PM
cj24's Avatar
cj24
Default 2019 vs 2020 Service Manual
I have a 2019 forty-eight special and looking to pick up a service manual. I can get a used 2020 manual... I'm sure there are not many differences between the years ... if any. Correct?
Old Feb 8, 2022 | 03:24 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I can't answer your question but only offer that HD from time to time change how some fasteners are done up. One example is the bolts that hold the rear belt pulley. The bolts haven't changed but in 2008 they were done up to 60 ft-lbs with threadlock. In 2017 that changed to using 2 different settings and a procedure like they were stretch bolts going from 60 ft-lbs to a final 80 ft-lbs. No Loctite and single use.
I only have those 2 years so I don't know when the change happened.
Old Feb 8, 2022 | 06:46 AM
John Harper's Avatar
John Harper
Sounds good to me. Gotta be close enough.
John
Old Feb 8, 2022 | 01:58 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The only mechanical difference that I'm aware of is the length of the rear shock absorber mounting bolts, 2004 to 2019 upper bolts are 1/2-13 x 2-1/4" and the lower bolts are 1/2-20 x 2-1/2". 2020 to 2021 the upper bolkts are 1/2-13 x 2-1/2" and the lower bolts are 1/2-20 x 2-3/4".
Old Feb 8, 2022 | 02:41 PM
cj24's Avatar
cj24
Thanks for the replies guys ... although I'm sure there are hardly any differences ... and given your input ... I think I will just spend the extra 50 bucks for the 2019 manual. Cost for a peace of mind I guess.
Marklovell90
Mar 10, 2019 12:15 PM
Mikeduke108
General Topics/Tech Tips
Jun 7, 2014 06:54 PM
whataboutbob
Jun 9, 2012 09:11 PM
bluebagger06
Dyna Parts
Jun 27, 2011 09:02 PM
Knight2
Jun 6, 2010 12:58 PM
