compatability
Old Aug 12, 2007 | 01:08 PM
redders's Avatar
redders
4th Gear
Default compatability
can anyone let me know if 1200 sportser parts are interchangable with an 883? ie exhuast pipes and hyperchargers? ta redders
Old Aug 12, 2007 | 01:24 PM
Thumper26's Avatar
Thumper26
Default RE: compatability
As far as I know, the only differences between the 2004-2006 883 and 1200 Sportsters are the cams and bore. Seems to me the stuff you're talking about should be fully interchangeable - assumming they're in the 2004-2006 "vintage". The years you're talking about would be helpful!
Old Aug 12, 2007 | 03:26 PM
SportyPig's Avatar
SportyPig
Are the cams different? I didn't think they were. I thought the only difference was the jugs, pistonsand heads.
Anyway, exhaust and air cleaner stuff should fit either 883 or 1200 Now, certain pipes and air cleaners might perform better on one or the other of the models, but they should fit fine.
Old Aug 13, 2007 | 11:14 AM
WVHogRider's Avatar
WVHogRider
I see you have a '98 model 883. Yes, Exhaust and Hypercharger are interchangible between the 883's and 1200's. Just make sure the parts are for the pre-2004 models.
Old Aug 13, 2007 | 12:25 PM
OldFenderGuy's Avatar
OldFenderGuy
ORIGINAL: SportyPig
Yes, the 2004+ 1200's also use high performance cams, which are different from the 'stock cams' used in the 883's.
Here is part of a HD article of changes to the 2004+ Sportsters;
"The XL Evolution 1200 engine has high-flow cylinder heads with an oil drain-back feature. The XL Evolution 1200 engine is also fitted with high-performance cams for enhanced torque output. Compression ratio is 9.7:1."
Old Aug 13, 2007 | 08:21 PM
Zimbob's Avatar
Zimbob
In the 2004+ sportsters, the cams HD used were the old (pre) 2004 Buell cams. As ear as being compatable 883 to 1200, pre 2004, yes. After 2004, should be as well, you just can't mate some things together from pre 2004 with 2004+ models. Hope this helps.
Old Aug 16, 2007 | 02:51 AM
redders's Avatar
redders
4th Gear
cheers for the info unfortunatly i have been outbid on ebay to the point where its not worth buying second hand. ta redders
TestFlyer
May 27, 2023 10:46 AM
S P
Apr 11, 2018 07:33 AM
Mr_Taipan
Apr 20, 2016 01:05 AM
maxhighlife
Nov 1, 2010 03:46 PM
ranger50
Oct 20, 2010 06:34 AM
