Multiple issues
Old May 23, 2022 | 07:44 AM
Shepherd1972's Avatar
Shepherd1972
Default Multiple issues
I have a 2004 Sportster 1200 custom. Here's what's happening. The other morning it started just fine , went out on it and the engine light came on,speedo went to zero and it back fired. So went home and looked at the battery cables. I ended up replacing the positive cable. Ran it exactly like factory. Now it pops the battery fuse. I looked to see if the anything was grounding out, but can't find anything. Checked the ground on the chassis behind the engine and it was clean and tight. Feeling very frustrated
Old May 23, 2022 | 08:28 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Go back and re-check the routing. Look at the connections with a volt/ohm meter, somewhere there is a direct short.
darryl melnyk
General Topics/Tech Tips
Jun 7, 2020 10:42 AM
David Butler
Aug 8, 2019 09:52 AM
SargeJ
Sep 19, 2018 10:09 AM
firemouth
Electrical/Lighting/Alarm
Jun 21, 2016 04:43 PM
zion
Mar 30, 2013 06:55 PM
