Hesitation/stalls while idling in neutral. Help! (09 Nightster)
So far I've replaced spark plugs / plug wires, o2 sensor, crankshaft position sensor, and cleaned the throttle body. Fuel pump seems to be fine, couldn't find any leaks or damage to the hose either.
I had the check engine light come on only once, and the code was P0132. According to google, this means the engine is running rich. I cleared the code though, and it has not came back on, but the issue continues.
I bought this bike (09 Nightster) used last summer, everything is stock. I put a new battery in it a few months ago and put about 300 miles on it since these issues began. I also double checked the battery connections and everything is tight.
Any advice would be much appreciated!
