Stalling after oil change
Old Jun 1, 2022 | 02:07 PM
kylemac1313's Avatar
kylemac1313
Stage III
Default Stalling after oil change
I've tried to find something on this and can't probably because I'm impatient and don't feel like reading through a million threads. Anyways if there's already a thread point me to it please.
So changed the oil on my 2014 iron 883 rode it a couple trips around the block. No more than five minutes. Been in the garage for a week cuz work sucks go for a long ride today after about an hour at around 4500 rpm it starts stalling out losing power. Engine light pops on for a sec then goes off then shutdown light comes on and the oil pressure light flickers. Pull over check for leaks, plenty of oil in the tank. Only about two miles from home so I start it back up does good for a bout a half mile then completely dies.
I got it home but I'm just not sure what the cause could be. I've heard of airlocking on some sportbikes but couldn't find anything saying sportsters had this issue. This is the first oil change I've done on this bike. Bike has 7200 miles on it (no not the first ever oil change I got it used). Any help is appreciated. The bike has always been fine besides the normal Harley blowby in the filter.
Old Jun 1, 2022 | 02:14 PM
2500hdon37s's Avatar
2500hdon37s
An hour at 4500rpm?
go search “sportster sumping”
oil is pooling in crank case faster than it can be scavenged/ pumped back to the oil tank. Thus the excess oil in the crank case is slowing the crankshaft.
Old Jun 1, 2022 | 02:17 PM
kylemac1313
Stage III
Originally Posted by 2500hdon37s
An hour at 4500rpm?
Not staying at 4500 rpm for the hour. It rode completely fine for an hour. Then when I was riding through town with stop signs and such it would be fine until I hit about 4500 rpm.
Old Jun 2, 2022 | 03:01 PM
hdbob2006's Avatar
hdbob2006
Simple things first: Check your battery cable connections.
Old Jun 2, 2022 | 10:48 PM
Angelfire36's Avatar
Angelfire36
Or maybe it's your voltage reg. connections? During oil changes, if you are not careful , oil will drip and deteriorate the connections.
Old Jun 3, 2022 | 03:07 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Engine check light on. See if any codes have been stored - Harley Trouble Codes (fuelmotousa.com)
Did you run the engine first before draining the oil?
How much oil did you put in?
After your five minute run round the block did you check the oil level?
Chambeaux
Engine Mechanical Topics
Apr 18, 2020 05:50 PM
elchoche23
Oil Archive (no new posts)
Jun 16, 2018 10:11 PM
Scot7449
Mar 19, 2015 10:49 AM
pjsonnentag
Oct 12, 2012 09:13 AM
Strgzr
Exhaust System Topics
May 1, 2011 10:06 AM
