Help
Old Jun 16, 2022 | 05:04 PM
Idkimnotcreative's Avatar
Idkimnotcreative
1st Gear
Default Help
Post pushrod installation I have this clicking sound and the rpm isn’t stable. I’ve took them off and put them back several times. Any know what it could be.
Old Jun 17, 2022 | 05:20 AM
shanneba's Avatar
shanneba
What year / model Sportster do you have?
The Intake and Exhaust pushrods are different length on the EVO Sportsters., do you have them in the correct location for Intake / Exhaust ?
Position Color Band length inches cm
Intake Orange 10.746" 27.295 cm
Exhaust Purple 10.800" 27.432 cm
Old Jun 17, 2022 | 12:05 PM
Idkimnotcreative
1st Gear
This is my first Harley it’s a 2009 sportster 883 low. I was thinking about pulling the rockers off and checking to see if maybe I installed them wrong or cause any damage to valves etc.’
Old Jun 17, 2022 | 01:20 PM
shanneba's Avatar
shanneba
Are you putting the cylinder you are removing / installing the rocker box at TDC on the cylinder's compression stroke?
  • It's very important to position the motor correctly before attempting to remove / install a rocker box. Not only must the motor be at or near top dead center (TDC), but it must be at the correct TDC.
  • A four stroke engine makes two complete revolutions to complete it's cycle, and therefore the piston passes through TDC twice.
  • One of those times is overlap TDC, which has the valves slightly open. You do not want to remove or install the rocker box with the motor in this position.
  • Turn the engine one complete revolution from overlap TDC to get to compression TDC. Both valves are closed at compression TDC, so this is the position you want to remove / install the rocker box.
  • An easy way to tell if the motor is at TDC is to turn it forward while watching the intake lifter or pushrod. You will see the lifter or pushrod go up and then down again. The next TDC that occurs after it goes down is compression TDC.
NOTE To avoid damage to pushrods or rocker arms, do not rotate crankshaft until both pushrods can be turned with fingers. (Before you put the top rocker covers in place)
Old Jun 17, 2022 | 03:32 PM
Idkimnotcreative
1st Gear
See video I’m so confused
File Type: mov
Old Jun 17, 2022 | 05:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What type pushrods, one piece or adjustable?
From the sound of it, I suggest a compression check...
Old Jun 17, 2022 | 07:06 PM
Idkimnotcreative
1st Gear
Old Jun 17, 2022 | 07:07 PM
Idkimnotcreative
1st Gear
I got the quickie adjustable push rods along with new lifters
Old Jun 17, 2022 | 07:58 PM
TexasScooterTrash's Avatar
TexasScooterTrash
To adjust the push rods PROPERLY you need to change the solid tubes to the "old design" 3 piece ones. Adjust the lash when the lifter is at it's lowest position, with the push rod tube collapsed. Adjust and move on to the next one. FYI - ya need to remove the heads to change push rod tubes. Much easier and LESS CONFUSING to simply put the original push rods back it.
Old Jun 19, 2022 | 07:26 AM
Racepres's Avatar
Racepres
Unless the Bolt Cutter Removal Method was employed!!!! I am Never in that kind of Hurry.
