Where/How does the VOES Mount?
Old Aug 13, 2022 | 01:55 AM
someguitarguy's Avatar
someguitarguy
Default Where/How does the VOES Mount?
While rerouting my fuel line today, I found the VOES unit was simply resting under the tank with the vacuum line pinched due to the previous fuel line routing. The bracket and switch are still in place but I don't see where it's supposed to mount. I trimmed off the end of the vacuum line so VOES should be working now, but would like to mount it properly.
All help appreciated.
Old Aug 13, 2022 | 08:01 AM
John Harper's Avatar
John Harper
Mine mounts to the backside of the upper engine mount, between the heads.
John
Old Aug 13, 2022 | 05:29 PM
someguitarguy
John
Here? If so, huge thanks. Kinda looks like it should go there. Also, is your VOES vacuum line clear?
Old Aug 13, 2022 | 08:01 PM
John Harper
Bingo! My bracket is not cut out like yours, as my petcock is on the right side. Just bolt it on the backside and you're good!
IIRC, I used a 3/16" vacuum/fuel line from VOES to carb. The VOES is actually useful, so you want it to work.
That clear tubing is good for overflow hose, but not in a vacuum/heat /fuel/gas application.
John
Old Aug 14, 2022 | 02:12 PM
someguitarguy
John
Ya, I wondered about the clear fish tank type tubing. Not surprised as I've had to straighten out a few other examples of jack leg engineering. Thanks for the mounting info. Picked up the hardware today. My local dealer actually had the bolt, washer, and locknut.
FrankenCub
Apr 11, 2022 06:14 PM
NascarGuy
Touring Parts
Mar 21, 2013 05:31 PM
1sweetglide08
Touring Parts
Dec 24, 2012 03:18 AM
Ole T Sport
Apr 28, 2011 06:10 PM
StanfordMan
Apr 29, 2010 06:53 PM
