Have not replaced any fuses
I don't know if the tail light works with the ignition on. That is one of the blown blubs
Horn has not work since about 2 days after i bought the bike 11 years ago
The head light does not work. However the high Beam does
The left (sitting on the bike) does turn on now, but does not blink due the the rear bulb been blown
The right side (sitting on the bike) I don't know because both bulbs where blown
Again cant answer question about tail/brake light
Oh and i am going to the store to buy some bulbs shortly and will report back, but the headlight might be an issue.
Also the trun signals on the indacator (by the netural light) are working now, they were not working early
I have put a test light in where the fuse goes and it is hot. Took out the 4 fuses and check them for resistance and got the sme reading on all four fuses. However, i am not sure if that did, does, or could mean anything
I have every light working correctly now. I have used a test light and know that i am not getting any power to the pink wire that runs to the coil, while the white/black wire is getting power.
On any H-D I ever worked on... the pink wire is for the Tach... Should be on Trigger side of Coil..Not with White wire...that is switched 12v
Trouble shooting is a step by step process. A lot of if not this tan this to it. Mix in the very good chnace more than one issue is involved. Details are a must.
Really Dan
If you would to look i have answered EVERY question you have asked days ago. If you would take i minute and scroll through the post you would see that, maybe put on your glasses or something
Thank you
