How to install quad ring
My genuine H-D parts manual calls it a "Clutch Inspection Cover Gasket", not a quad ring.
Rob Roy's Revenge, mine does not look like your picture. The way it is laying in the picture, the flat side is not on the top and bottom, on mine it's on the inside and outside. I have seen it called many different things.
Ronnies H-D calls it a 25463-94A
GASKET, CLUTCH INSPECTION COVER
J&P Cycles calls it an O-ring for Derby Cover
http://xlforum.net/forums/showthread...ad+ring&page=2
This post on XLforums calls it a quad ring
My Clymer manual calls it a quad ring.
Thanks for all the help. It was becoming obvious that something was wrong with the new part I have. Bob
But, what about the old one that was there when you first opened it? Did it look like the picture?
If it looks like an OH and fits like an OH it should be called an OH dammit. LOL
2006? Your bike is a wee lad compared to my 1991. Aftermarket exhaust systems seem to be the hardest parts to find for older bikes. Luckily, our motors are rock solid and not much has changed since mine was made.
Also, unless doing a clutch adjustment (rarely needed) you don't need to remove that cover. Just drain the primary fluid and refill through the inspection cover. One quart is all you need, you don't have to check the level. Just make sure you remember to refill it with one quart once you drained the old. I use Bel Ray STL, others choose differently.
John
Doing a clutch adjustment is what started all this. My clutch was not disengaging until the lever was almost against the grip, even when adjusted to the point where there was almost no play in the lever. After removing the cover, I turned the adjustment screw about one turn to the right to loosen it, then turned it back until I barely felt resistance, then turned it right 1/4 turn, and put the spring and locknut back on. Because of the gasket problem I have not been able to check it yet. If it still engages with the lever too close to the grip with the cable adjusted properly, do I need to loosen or tighten the adjustment screw under the cover?
