Use the stock tyre size that H-D recommend, your tyres are the only thing between your motorcycle and the highway, the stock sizes are proven to be safe by the motor company.
Well, if the MoCo says it's safe then it must be true.
Isn't motorcycling considered to be inherently dangerous to begin with?
It doesn't matter much. Stock size for my bike was a 130 and I went to a 150. The rubber mounts went to a 150 and have the same geometry so apparently the MoCo decided it looked better with a 150. A 180 is too much. The bike would resemble Kim Kardashian.
My rear wheel is 4.5" wide and that is fitted with a 150 tyre.
I like that look, especially on a lowered bike.
I think the coolest looking Sportster I've ever seen was a lowered, stripped down early 60s Iron Head with polished aluminum rims, 130 on a 4.5" rim out back
I like that look, especially on a lowered bike. I think the coolest looking Sportster I've ever seen was a lowered, stripped down early 60s Iron Head with polished aluminum rims, 130 on a 4.5" rim out back
Now you're really getting dangerous. The safety police are going to cite you.
Hello, everyone. I am the owner of a 2015 Forty eight and I am thinking of changing the rear spoked wheel RIM for a 4.25 inch one (stock is 3 inch). If I buy the 4.25 RIM and the spokes, can I change them to put a 170/70 -16 tire using the original remaining parts of the wheel? I think it is the easiest conversion to fit a wider tire safely following the wheel manufacturers recommendations of tire and rim width.
Thanks.
B.
Thanks.
B.
The rim would need to be drilled for your specific hub or you could run into problems!
