delete or relocate dash lights.
Old Nov 16, 2023 | 10:54 AM
Connor White's Avatar
Connor White
2nd Gear
Default delete or relocate dash lights.
I have a 2001 XLH 883. I've done a speedometer relocation but left the dash lights on the stock top clamp. I'm looking at switch to a set of riser-less bars and don't really know what to do with the dash lights. should I buy another speedo bracket that has the dash lights attached? Can I relocate them somewhere else? Or is it just easier to get rid of the all together?
Old Nov 16, 2023 | 11:41 AM
RKZen's Avatar
RKZen
Welcome from across the pond.
Since you did a speedo redo, I would also relocate those lights. Koso has a light set you can splice up here. It comes with a bracket. I'm sure others can point you to other brands.
Old Nov 17, 2023 | 08:03 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Did you reuse the stock speedo when you relocated it? If so, where did you move it to? It might make sense to move the dash lights with it.
Old Nov 17, 2023 | 09:50 AM
96hugger's Avatar
96hugger
I just depinned mine and tucked it under the tank after my Speedo broke lol, you should check out older clamshells or just drill holes in yours if you want to keep the lights functional.
Old Nov 20, 2023 | 10:01 AM
Connor White
2nd Gear
yep still the OEM speedo. its mounted to the left side of the tank. using the front tank mount bolt. there are mounts that have the dash included. kind of wish i bough one of them now.
Old Nov 20, 2023 | 10:02 AM
Connor White
2nd Gear
Old Nov 20, 2023 | 10:03 AM
Connor White
2nd Gear
did you find that easy enough to do. plus how are you finding not having them there?
Casper
Aug 9, 2014 11:41 AM
nickybandy
Jan 17, 2013 07:19 PM
clucker
Jan 6, 2010 06:45 PM
bberck
Sep 9, 2008 04:11 PM
Taterdog
Jul 24, 2008 10:54 PM
