2014 Iron ignition issue
Old 04-22-2024, 10:30 AM
Dingo94's Avatar
Dingo94
Dingo94 is offline
Stage II
Default 2014 Iron ignition issue
Hi guys,
I’ve recently had an issue when switching the ignition on. Literally nothing happens, the fob is present to disengage the alarm but nothing.
I’ve changed the battery in the fob, i’ve changed the battery in the bike. Nothing doing.
After taking apart the casing of the ignition iv’ve notice that the part of the circuit board that the ignition switch goes to has some small black marks on it.
So I gave my local harley garage a call and they said it can be common in the 2014 models.
My question is, do I bite the expensive bullet of buying a new unit for it to potentially happen again or can I fit a key ignition where the steering lock is or elsewhere?
Thanks in advance for any advice. In light of this issue i’ve used it as an excuse to strip the bike and give it a full makeover. So any more bits and bobs that you’d recommend I add whilst she’s stripped are more than welcome!
Old 04-23-2024, 06:04 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 13,387 Likes on 5,712 Posts
Welcome to the board.
When you say nothing happens what does that mean? Do your lights come on? Can you hear the fuel pump priming? Or is there literally nothing at all happening.
Old 04-23-2024, 06:09 AM
Dingo94's Avatar
Dingo94
Dingo94 is offline
Stage II
Literally nothing at all. If you zoom in on the picture of the circuit board you’ll notice some black spots where the ignition on switch is.
I’m assuming the previous owner opted for the HD security keyless start. Hence no key
Old 04-23-2024, 06:41 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,768 Likes on 2,424 Posts
The engine stop switch as it is called is not part of the CAN bus system but I don't know if it switches a voltage or some resistance to ground, the wiring diagram doesn't show that.
If you could fit an ignition key you would still need the engine stop switch to work. There is provision for a key but that just goes to a different input on the BCM.
The UK bikes all come keyless from 2014.
I am assuming what you are holding is the electronics from the right hand controls?
I would give it all and the switches a clean with electronic contact cleaner and see if that fixes it.
Wiring diagram here - 99949-14_en - 2014 Wiring Diagrams (harley-davidson.com)
Dirty_Eight
11-12-2021 01:02 PM
micathia
11-16-2018 03:39 AM
edteach
11-21-2016 06:58 PM
bruinsh
Electrical/Lighting/Alarm
10-20-2016 08:38 AM
superdog48
02-15-2006 12:09 PM
Quick Reply: 2014 Iron ignition issue
