newbie stains on engine, please help
Old Aug 31, 2007 | 04:31 PM
Ricksports's Avatar
Ricksports
Stage I
Default newbie stains on engine, please help
Hi there,
being new to caring for a porous aluminum engine case, I must have done something wrong.
As I washed the bike, I used "supertech degreaser" to remove some greasy deposits around the head bolts.
Now, it is either the degreaser or just water staying on the fins for too long, but I created some bad black stains on the gray aluminum finsih.
I tried to remove them using Mr Clean Magic Eraser, it seemed to be working at first. Then I realized they were not really going completely away. In three spots I applied more rubbing and the stains were removed...but together with the finish coat. Now I have a couple of spots with very bright aluminum exposed. I read somewhere that these areas are prone to oxidation.
Is there anything I can do to protect these parts? a sort of touch up paint for the gray porous aluminum finish of the case?
Any suggestions on how to remove the remaining stains on the fins?
Thanks
Old Aug 31, 2007 | 09:18 PM
Zimbob's Avatar
Zimbob
Default RE: newbie stains on engine, please help
these motors are powercoated. useing anything that will harm paint can effect them. you might get by with some clearcoat, how long that will work is anybody's guess.
Old Aug 31, 2007 | 09:24 PM
Dallastx's Avatar
Dallastx
Show some pics. Anything you spray on the engine better be high heat and made for that application. Clear coat that is. On another note. Why do people use solvents on their bikes if they aren't sure if it is okay? Soapy water will do the trick. Anything else, ask.lol!!
Old Aug 31, 2007 | 10:52 PM
HighDesertKid's Avatar
HighDesertKid
How did you get "newbie stains" on your engine?.... Did a newbie spit on your bike? ... Sorry, that doesn't help at all [8D]
Old Aug 31, 2007 | 10:58 PM
Zimbob's Avatar
Zimbob
ORIGINAL: HighDesertKid
He hit a newbie and it splashed him I guess.
Old Aug 31, 2007 | 11:14 PM
Teek's Avatar
Teek
I thought newbie stains were when the bike is new, excitement! Then listening to that 45 degree single crankpin sound...more excitement...then staring into it's seductive headlights...much excitement...then in all the excitement.... Oh, never mind!
A do it yourself car wash works pretty well for me. High pressure soap and water does wonders for grease and grit. Just be careful not to drown the electricals. What you don't get off at the car wash, detail with some good all purpose bike cleaner...Honda Spray Cleaner and Polish works great! But they don't make it anymore...IMHO, chemicals should be applied with a relatively cool engine, and not left on too long.
Teek
Old Sep 1, 2007 | 12:57 AM
seikan1's Avatar
seikan1
How about just windex....it is what I was told to use to get the oil off. Works great.
Old Sep 1, 2007 | 06:05 AM
BadHabit's Avatar
BadHabit
I have a small rocker box leak...On my plain grey aluminum cylinders I just spray brake cleaner on the spots I want to clean...Works perfect. You do want to make sure you do not get this on the paint though.....
Old Sep 1, 2007 | 06:07 AM
Photo's Avatar
I thought newbie stains occured mainlyon the seat and were caused by not being used to the vibrations
Anthony Cole
Mar 15, 2018 02:42 PM
blackflame
Apr 9, 2013 03:56 PM
jasonyankees
Apr 3, 2008 03:16 PM
MR. SCOOTINN
Detailing
Aug 1, 2007 04:22 PM
rladkins
Exhaust System Topics
Apr 11, 2006 01:47 PM
