Isolating parasitic draw
Do as Dan stated to measure what the current draw is through the negative lead to the battery. You can do that easily on your bike as that it the terminal facing you under the left cover.
Maybe you should put it on a tender once a week and just ride the motorcycle until you're sure there is a real problem.
Not like the old days where you just turn off the petcock and disconnect the fuel line.
Don't mean to get some of you flustered. Just trying to have a conversation about, and getting to know a little bit better, these new-fangled computer controlled bikes.
In order to stop petrol under pressure spraying you, you have to disconnect the pump at its connector and then try and start the engine to depressurise the system before releasing the fuel line at the tank so it can be removed.
you'll discover that I asked if there was a procedure to follow, not that there was an issue.
I was hoping to start a discussion in order to gather information, to see if there was a problem.
I'm an older guy and not familiar with modern electronics on bikes.
I did a quick draw test and will try to attach a pic.
There was an initial higher reading while something (fuel pump?) was running for a few seconds and then it settled down and stabilized at this reading.
Set on 20ma. I'm not sure what the reading means exactly, but if it's 1.7ma, that seems to low according to a lot of the posts in this thread.
I'm also not sure of the accuracy of the meter, but it seems to reads volts like my other meters.
If this is normal, then I guess I have to plan on buying a battery every year.
Yes, I do usually use a tender, but with the battery I currently have in the bike,
The manufacturer recommends not using a tender unless you won't be riding for a month or so:
https://www.renegadebattery.com/prod...tery-300-ccas/
Hope I haven't riled everybody up too much.
It suggests a "battery spirit" brand charger that is sold by that website....just scroll a little down.
No sure why any of this means you need to buy a battery yearly.
People are just going to ask questions, I don't think anyone is riled up. relax.
Testing draws, is not exactly a young man's thing either. People have been doing that for awhile maybe even more with old vehicles.
I am out of here as failure to answer simple questions when folk are trying to help that go unanswered just wastes everybody's time and effort.
So if you want to strike up a conversation reply to the posts and don't ignore them.
