Help please
Old Sep 17, 2024 | 02:22 PM
Sportster Brian's Avatar
Sportster Brian
2nd Gear
Default Help please
I have a 2000 Sportster XL1200c , my ignition control module went bad and there are none available so I had to get an after market one. I got an ACCEL 35496 single/duel fire programmable. It only shows 3 wires for duel fire but my original has 5 wires coming from it, does anyone have a wiring diagram that shows all 5 wires.
My original module
Old Sep 18, 2024 | 08:49 AM
Von_Zipper's Avatar
Von_Zipper
https://documents.holley.com/35496rev.pdf
I don't know, these instructions state 35496 is for 1978-99 bikes. Anyhow, later in this PDF are wiring diagrams. You certainly had a look at these instructions, what exactly is confusing you?
Old Sep 18, 2024 | 10:28 AM
John Harper's Avatar
John Harper
The wiring diagram that VZ posted looks pretty clear to me. Blue and brown wire are unused.
John
Old Sep 20, 2024 | 09:15 AM
Sportster Brian
2nd Gear
Default Not confused
John
Yes the blue and brown wires are not used on the new module, what I want to know is what the 2 wires control on the bike, am I cutting out something I might need. I do my research so I don't create a new problem.
Old Sep 20, 2024 | 10:30 AM
John Harper
The instructions show one wire for "single fire" configuration (blue) and the other for the tach (brown).
John
Old Sep 20, 2024 | 11:28 AM
Sportster Brian
2nd Gear
Default Understood
However that does not answer the question I have, which is, what do the other 2 wires on the bike go to. I don't like cutting cutting out wires without knowing what they control. Could cause other problems.
Old Sep 20, 2024 | 11:35 AM
Madnss's Avatar
Madnss
Look it up in the factory service manual, it’ll tell you what they are.
Old Sep 20, 2024 | 01:48 PM
Von_Zipper's Avatar
Von_Zipper
Your bike is 2000, this module is for bikes up to 1999. How can you be sure it even fits your bike?
Sportster Brian
Sep 30, 2024 02:22 AM
RohsHeck
26
Dec 5, 2023 11:15 AM
Steady birage
Jun 17, 2021 09:16 AM
lstubbendeck
Jul 19, 2016 09:01 PM
ddellostritto
Mar 18, 2013 03:30 PM
