Leaking oil from engine into primary case
Old Jan 18, 2025 | 07:51 PM
thatcarguydownthestreet's Avatar
3rd Gear
Without the nut holding the spacer, oil can leak out of the crankcase.
Someone else also mentioned this, and I wish I'd known sooner however replacing the seal doesn't seem like such a bad idea anyways.
(I also already removed it)
Old Jan 18, 2025 | 07:52 PM
3rd Gear
Originally Posted by cncmike
The easiest way to install the new seal is to buy pvc pipe or a pvc fitting to put on the end of a 8" pipe with an outside diameter as close to the diameter of the seal. This will allow you to tap the seal in squarely.
Thanks for this, I'll run down to the hardware store next time I get the chance.
MMH
Oct 7, 2022 09:30 AM
sumncguy
Milwaukee Eight (M8)
Oct 2, 2022 07:16 AM
marktruckee
EVO
Jun 21, 2019 11:01 AM
RJM
EVO
11
Mar 26, 2013 09:59 PM
D1gger
EVO
Jun 11, 2012 04:16 PM
