I need advice?
Old Oct 15, 2007 | 04:53 PM
08 1200L's Avatar
08 1200L
Default I need advice?
I just bought a new pair of vance and hines slipon, can I put them on without doing anything else to my bike? They are going on a 08 1200L, I have heard that I needed a fuel-pack, then someone told me that I didn't, if I do are they hard to put on. Any feed back would be great.Thanks
Old Oct 15, 2007 | 07:52 PM
dbleagle's Avatar
dbleagle
Default RE: I need advice?
Changing exhaust... no problem... and though I haven't done it to your particular model... installation isn't hard at all...
Charlie D.
Old Oct 15, 2007 | 08:07 PM
08 1200L's Avatar
08 1200L
Thanks for the feed back, do you know if I have to get it remap or anything
Old Oct 15, 2007 | 08:15 PM
pingman68's Avatar
pingman68
I would just for the fact that they run really lean from the factory, but I have heard it's not crucial to do so.
Old Oct 15, 2007 | 08:27 PM
08 1200L's Avatar
08 1200L
I will as soon as I can, I was told that if I baby it, it would be ok How do you baby a sporty
Old Oct 15, 2007 | 08:29 PM
jc_denton's Avatar
jc_denton
Technically if you put on Screamin' Eagle mufflers by themselves you don't have to do anything else to your bike. Vance & Hines may be the same way, I don't know. What I do know is that if you put the pipes onand a high-flow air cleaner you do need to get the Fuelpak.
Quite honestly, I think as long as you don't change the amount of air entering the engine you don't need a Fuelpak. Just because the air can exit better doesn't mean the engine needs a Fuelpak, but it may change the back pressure, which in turn can change performance.
Bottom line, I guess I personally would not install them without a Fuelpak, BUT Fuelpak only has programs for bikes with high-flow air cleaners. So if you don't get the air cleaner, too, don't bother with the Fuelpak I guess.
Old Oct 15, 2007 | 09:26 PM
08 1200L's Avatar
08 1200L
I guess I'm going to try them by theirselfs first, all I know is more air in and more air out gives more hp, I'm just changing more air out, hopefully it want burn my valves thanks for the info, as soon as I can I will change my air cleaner and get a fuelpak
GTK
Oct 21, 2016 02:04 PM
JPKaty23
Exhaust System Topics
11
Apr 23, 2015 08:33 AM
bowhunter031172
Jun 7, 2009 11:08 AM
07yellowglide
Aug 24, 2008 07:28 AM
BK Meyers
Aug 22, 2008 08:52 AM
