sporster seems like it needs a 6th gear
Old Oct 25, 2007 | 11:04 AM
  #31
Telefishin2k's Avatar
Telefishin2k
Default RE: sporster seems like it needs a 6th gear
So, I gather from the above posts that my supposedly stock '93 883 is turning mid 3000's at 65-70 mph?...Bitch seems like she's gonna fly apart at that speed, was just curious about the rpm at hiway speeds.
Old Oct 25, 2007 | 05:50 PM
  #32
shortsport's Avatar
shortsport
4th Gear
that's exactly what I'M saying, it sounds like it's going to come apart, even though it is an 06, most likely same motor as yours.
Old Oct 25, 2007 | 06:12 PM
  #33
risonite's Avatar
risonite
Shortsport, the 30 tooth is part #40380-04. I got mine from Surdyke Harley online for $50.76. It works fine with the stock belt. The final drive ratio will be 3.80, roughly halfway between the stock 883(4.07) and the 1200(3.50) I don't have any before and after times, But I think the bike may be a little quicker due to the higher gearing keeping the engine in the 'fat' part of the torque curve a little longer. It still has no problem 'holeshotting' my bud's TC88 Heritage, if that helps.
Old Oct 26, 2007 | 07:48 AM
  #34
jc_denton's Avatar
jc_denton
ORIGINAL: Telefishin2k
No. If you're on an 883 (stock gearing, etc.) it should be around 3,800 at 70mph in 5th gear. Technically, if you hold an 883 exactly at 4,000 rpm in 5th gear you'll sit around 74mph. So if you're going about 74mph in 5th, you can assume it's at 4,000 rpm.
EDIT: And yes, the 883s do sound like they're breaking when you're going that fast. The 1200s for some reason don't make those sounds, though.
2013superglideseattle
Milwaukee Eight (M8)
20
Aug 13, 2017 08:33 AM
stevieg
Oct 10, 2014 02:29 AM
03psd
Jul 2, 2012 10:33 PM
95hd883
May 20, 2008 10:03 AM
Puttnutt24
Aug 1, 2007 06:41 AM
