Put a little vasoline on the gasket to hold in place. You are right...should have done it with the bike upright. Fluid level should be brought up to the bottom of the clutch diaphragm spring. Another way is to drain, then fill with the proper amount via the inspection cover, if the derby cover is in place.
If you are in doubt, you can drain the remaining oil and just refill with 1 quart (32oz).
That's what I would do. Just drain the tranny.And replace through the primary chain inspection cover, that way you don't have to worry about the quad ring. cHarley gave good advice about keeping the quad ring in place, but trust me...you don't wanna risk that thing comming out. It's a MAJOR Pain in the A$$ to get back in!! Would be a good time to switch to some Mobil 1 gear oil for the tranny.
Yes, you hear the voice of experience talking here.!!
Oh, and your original question, I did the same thing. Followed the instructions to replace the derby cover. And pretty much about the same amount of fluid leaked out.
[/quote]
That's the answer to holding the gasket in place... It's the only part of the process that is a little difficult.. Seal it..... Run it.... If it leaks.... Then the gasket isn't sealed.... I used a lil vasoline and she slid right in.
Methinks a Service Manual is the way to go. I have had a fair few problems due to poor information from dealers and poor instructions included with Harley parts. Thanks guys.
fyi- most hydraulic and auto stores sell "pig blankets" which absorb oil, water, brake fluid,and coolant. the "pad" is about 19"x19"x 1/8" thick or so. each pad will absorb 19.1 fluid oz.
REALLY handy for oil changes and primary changes.
i always use one if there is a doubt something might drip. heck, if it doesn't, toss 'er in the cabinet for next time.
hydraulic stores usually sell them for $ .30 each.
fyi.
doing fluid on the scooter is about a three beer project...... the returns pay for the pig blanket[sm=icon_guiness.gif][sm=icon_guiness.gif][sm=icon_guiness.gif]
Maint manual on order! In meantime I will go the route of draining the oil and re-filling. Do I need to get a new washer for the drain bolt first, andwhat/where is the inspection cover?
