Thanks Kolni...will vacuum gauge for car work the same for m/c? A carb's a carb....will check Autozone tomorrow.
Vacuum is vacuum. Doesn't matter if it's a car or truck or a Hoover. You should be able to use an automotive vacuum guage with a great amount of success. Go with a higher quality unit as the cheaper units aren't as accurate.
