Help with starting problem
Old Jan 25, 2008 | 03:13 PM
MoTohEaD's Avatar
MoTohEaD
Default RE: Help with starting problem
Sorry I cant help, just turn the key, flip the switch and hit the button. boom the only reason i like efi
Old Mar 27, 2008 | 07:15 AM
mogziecm's Avatar
mogziecm
Stage II
Had my 883r stood for 3 months, charged battery, gone to start her up, just getting repeated clicks and no start, o forgot to mention changed tank first, anyone got any ideas before i hand over to a harley stealer
Old Mar 27, 2008 | 11:28 AM
Sundog's Avatar
Sundog
mogziecm
If you are certain your battery is charged, make sure alll your conections are tight in the starter circuit, especially at the battery. If not, try jumping it from a car to eliminate the battery question.
You could also try to push start it. I used to park mine on a hill when the battery got flakey. Use second gear.
Old Mar 27, 2008 | 04:46 PM
MoparScott's Avatar
MoparScott
6th Gear
I had problems getting mine started, called the service center. they said i wasn't getting enough gas. I bought a medicine dropper pulled the plugs out, put a couple drops of gas in each cylinder, put the plugs back in and tried firing it up. It ran for a second than died. I hit the throttle about six times and it stated.
wojeepster's Avatar
wojeepster
The fact that you smell gas means to me you are getting it, but to make sure unscrew a plug and smell the end. Then check for spark and go from there. Check for spark, check for gas, and go from there. A shot of either (starting fluid) can help start arecalitrant engine.
Harleydarley
May 30, 2018 07:16 AM
charris
Jan 23, 2014 11:44 AM
vinzilla
Aug 18, 2012 10:38 AM
128auto
May 16, 2008 10:24 AM
max290
Aug 11, 2007 09:34 PM
