forward conrol conversion questions
Old Mar 18, 2008 | 09:36 PM
brian falcone's Avatar
brian falcone
Default forward conrol conversion questions
found a set of new forward take offs from an 06 1200c...the stock harley ones....theywhere a decent price and i want to put them on the 1200r....looks like i need to remove the exhaust to reach the allen bolts on the brake pedal/left peg mount.......question is ...is there a gasket in the exhaust where it meets the head?or is it simply bolted up there and theres no gasket. dont want to take anything apart untill i know i have everything i could need to reassemble.i figure it would be wise to replace any gaskets before assembly....any help would be great.
Old Mar 18, 2008 | 10:01 PM
carlo's Avatar
carlo
Default RE: forward conrol conversion questions
The 06 HD service manual says to replace muffler interconnect gasket and exhaust port gasket and torca muffler clamp. I would get the service manual then go from there. You might be able to loosen exhaust pipe flange nuts and remove flanged bolts that hold muffler to muffler interconnect bracket to lift muffler up a little toget to the rear brake rod assembly. Id get the service manual you can't go wrong with it. Its well worth the money spent.
Old Mar 18, 2008 | 10:05 PM
6o66er's Avatar
6o66er
The gasket is pressed into the head....I take my pipes off all the time and it just stays in there...I wouldn't really worry too much about it, honestly.
And +1 on the SM....GET ONE.
Old Mar 19, 2008 | 06:55 PM
brian falcone
thanks guys..ill go order a service manual...brian
Old Mar 19, 2008 | 08:46 PM
nevets61's Avatar
nevets61
Like 6o66er says, gaskets are pressed in. They are easy to change but no need most of the time. The are pretty resilient and can be reused several times, along with the clamp and nuts. Just be sure to get the pipe set in straight, tighten nuts to proper torque and no worries...
Sootylad
Oct 13, 2015 09:29 AM
DaddyKnuck
Aug 11, 2015 11:26 PM
ripto
Jul 1, 2015 01:45 PM
wlibert
Apr 10, 2011 10:37 AM
ionate
Apr 25, 2007 08:38 PM
