Lights Question
Old Mar 22, 2008 | 11:54 AM
JRK5892's Avatar
JRK5892
Default RE: Lights Question
you can run a jump line from your headlight line (brights)to your fog power, as of right now it just is plugged into your headlight (regular light) that is why when you flip the brights it goes off, a bridge would allow the power to flow
Old Mar 22, 2008 | 12:05 PM
cHarley's Avatar
cHarley
ORIGINAL: JRK5892
[sm=badidea.gif]
Doing that will short the seperate high and low beam circuits together causing both the high & low beam filaments of the headlamp to come on at the same time, not only creating very high heat in the headlamp housing but blowing the Lights fuse in short order.
TriGeezer
19
Oct 6, 2018 03:08 AM
hemi1300
Nov 22, 2014 09:09 AM
Herbkell
2014-2024 Touring Models
May 22, 2014 09:10 PM
DeluxeCruiser
Aug 3, 2013 09:34 PM
tabone75
Sep 17, 2008 08:10 AM
