Mirror issues
Old Mar 26, 2008 | 02:17 PM
jlsporty's Avatar
jlsporty
Default Mirror issues
Yesterday I took my bike out for a nice little 35-40 mile ride and noticed that one of my mirrors doesn't stay put. The pivot on the mirror seems loose so the wind just blows it so it's pointed in so I'm essentially looking at myself in the mirror. Is there any type of adjustment or fix for this or am I looking at having to replace the mirror?
Old Mar 26, 2008 | 02:23 PM
LdyMjo's Avatar
LdyMjo
Default RE: Mirror issues
I'm also noticing a bit of this with one of my mirrors--at the ball, and there seems to be no way to tighten it...
Old Mar 26, 2008 | 02:25 PM
whaap's Avatar
whaap
There's no adjustament. My first thought is I would get some clear silicone, get as much of it into the joint where the stem and the mirror come together. Set on the bike. Put the mirror where I want it and leave it alone till it sets up. Hopefully that will keep it in place. Be sure to adjust it where you want because you don't want to try and move it after the silicone sets up. Just a thought !!
Old Mar 26, 2008 | 02:30 PM
DSnoopy's Avatar
DSnoopy
Mine did the same thing, broke and than I replaced it.
Hey, it's parts from an America company, what do you want? [:-]
Old Mar 26, 2008 | 03:01 PM
jlsporty's Avatar
jlsporty
I had thought of going the silicone route but was thinking there must be a better way than that. It really wouldn't bother me if it was my right hand mirror I don't use that much but I use the left hand one all the time.
"Hey, it's parts from an America company, what do you want?"
LOL, very true.
Old Mar 26, 2008 | 03:03 PM
skipit's Avatar
skipit
Depends on the year.. there was a recall on mirrors for a while.. even after that I had trouble with the left one.. dont know why they didn't set thread up so you can tighten it against the wind...
Old Mar 26, 2008 | 03:30 PM
WVHogRider's Avatar
WVHogRider
Non-adjustable mirrors......[&:] Mine are adjustable. You can tighten the two screws at the ball pivot joint, as that's what they are there for. You can also adjust it at the stem base on the handlebars.....loosen nut on underside of handgrip, position stemas desired, and re-tighten the nut.
The two screwsfrommy right mirror fell out on a ride one day, and the mirror started spinning around like a windmill....Next morning I sawsalled it ride off....
Old Mar 26, 2008 | 07:49 PM
SpursDarkrider's Avatar
SpursDarkrider
my 07 left hand mirror blew back towards me my first time on the superslab,,,rode back home, saw the nut that tightens up the mirror stem,tightened it and never moved again. That was 1500 miles ago.
Old Mar 26, 2008 | 11:44 PM
Dorkman's Avatar
Dorkman
If you have the type that is non adjustable at the ball in back of the mirror, you are out of luck. A quality mirror is either adjustable with a couple of screws, or is very snug and can be twisted a bit. Biggest problem I had was the short stem mirrors would only reflect my arm, not much behind, no matter how much adjustment. Problem solved with a quality long stem mirror. Wider bars also help.
Old Mar 26, 2008 | 11:46 PM
schumacher's Avatar
schumacher
ORIGINAL: jlsporty
LOL, very true.
I'll overlook that comment........
