starting problems
Old Mar 27, 2008 | 07:32 AM
mogziecm's Avatar
mogziecm
Stage II
Default starting problems
Had my 883r stood over the winter, replaced tank, charged bettery gone to try and start her up, but all i'm getting is repeated clicks and no start, anyone got any ideas before I hand over to a harley stealer
Old Mar 27, 2008 | 07:39 AM
cHarley's Avatar
cHarley
Default RE: starting problems
Try cleaning and re-tightening both ends of each battery cable. A fully charged battery should measure 12+ volts if you turn the ignition switch to the ON position (lights on).
Old Mar 27, 2008 | 08:09 AM
Zimbob's Avatar
Zimbob
Double check the cables and anything else you have touched. I find by retracing my steps, I usually find my problem.
Old Mar 27, 2008 | 08:26 AM
Thumper26's Avatar
Thumper26
For some very annoying reason the battery cables are at fault in 95% of the situations like yours. It has gotten to the point on my bike where I check my FOUR battery-cable connections every month or two to eliminate the surprise no-start at 1:00 in the morning when I come out of somewhere and just want to get home. Frequently I find my negative battery cable loose, and more often that not, it is the battery connection end that is loose. I'm thinking of getting out the blue locktite for those four connections!
mlrailguy
Aug 16, 2015 06:49 PM
BigCheeseStick
Apr 28, 2014 01:57 PM
Petro
Dec 13, 2013 02:33 PM
Mr Mojo Risin
Jun 14, 2012 04:47 PM
bykeguy
Mar 19, 2008 06:31 AM
