sputtering
Old Apr 17, 2008 | 12:07 AM
MOSTWANTED's Avatar
MOSTWANTED
Default sputtering
I ran the bike out of gas Tuesday night, but I had enough in reserve to get me tomy usual station. I filled up, then rode about 100 milestoday and had to fill up at a different station. I then rode another 10 miles before it started sputtering in 4th gear @ about 60mph. I suspect bad fuel or a dirty fuel filter, but haven't had time to look at it yet. Any other ideas? I run 91 octane always, but I suppose that I have to rely on actual 91 coming from the pump.
Old Apr 17, 2008 | 02:41 PM
hogsport's Avatar
hogsport
Default RE: sputtering
My guess would be water/dirt in the gas. I would suck a quart off the bottom of the tank to check, or replace the tankful ofgas. I have had gas contaminated with diesel causing missing. If it just runs rough, itwill likelywork through it with good gas.
Low octane would cause preignition (ping) not missing.
Old Apr 17, 2008 | 03:22 PM
DeJavu's Avatar
DeJavu
Isopropyl Alcohol will eliminate water in the gas. Doesn't take much (2-3 tablespoons) and you'll be running normal. In humid climates it doesn't hurt to do this once in a while for insurance. The water combines with the alcohol and burns with the gas.
HDultralowGA
2014-2024 Touring Models
16
Oct 23, 2015 09:08 AM
steelerdude1
Jun 24, 2013 09:03 PM
waldhorn
Carburetor Related
Jun 11, 2012 01:59 PM
DannyZ71
Sep 16, 2011 10:36 PM
rex0350
Exhaust System Topics
Feb 5, 2008 06:54 AM
