Opening derby cover first time
Old May 1, 2008 | 09:26 AM
kelton3's Avatar
kelton3
Default RE: Opening derby cover first time
After reading the responses I'm going to leave the derby cover alone for now, at least until I become a bit more familiar with the bike. Thanks everyone!
Old May 1, 2008 | 10:25 AM
SportyPig's Avatar
SportyPig
ORIGINAL: thomasf59
If you do remove the derby cover apply some never seize to the threads of the fastners before re-installing them.
[sm=exactly.gif]
Frankly, I wouldn't remove the derby cover unless you absolutely have to. You can just add the tranny fluid through the primary chain inspection cover. I have had my derby cover off more times than I care to remember, but ONLY when necessary.
If you just insist on removing the derby cover, don't let the quad ring gasket come off. That is a royal PITA to get back in place sometimes.
Old May 1, 2008 | 11:54 AM
ride2tires's Avatar
ride2tires
Personnally, the first time I pull a derby cover off, I reach for the Milwaukee torx wrench. Had to on both bikes.
Drill the heads off, bolts will unthread by hand when cover is removed, replace with allen heads(stainless). Done.
Never have a problem again.
Best of luck.
Old May 1, 2008 | 07:06 PM
dbleagle's Avatar
dbleagle
I just use a "T" handle and a torx bit... give the handle a whack with a hammer and the bolt/screws come right out....
But I will say the allen head screws are a good idea.... don't know if they'll look as good though...
Charlie D.
Old May 2, 2008 | 06:37 PM
gammaray's Avatar
gammaray
Just avoid being an idiot
Old May 2, 2008 | 06:41 PM
Bradley Jones's Avatar
Bradley Jones
[quote]ORIGINAL: Mandog
ORIGINAL: gilmour68
Go your trusty ACE HARDWARE and get the chome allen head bolts and swap them out. lf you will need to remove the cover if you plan on doing your services.
Very good advise!!!!!!!!!!!! Those torxs blow
Old May 2, 2008 | 08:01 PM
PigInaBlanket's Avatar
PigInaBlanket
ORIGINAL: schumacher
Well, that's where the gnome that cancels your turn signals lives...so be very careful....
Old Jul 8, 2018 | 12:41 PM
Free Bird Too's Avatar
Free Bird Too
6th Gear
So are the Milwaukee Eight 5 hole derby covers different that the earlier 5 hole derby covers?
I just got an M8 powered 2017 Freewheeler and was planning on replacing the stock derby and points covers with aftermarket ones. Are the M8's a unique configuration vs earlier derby covers.
(God I miss the days when you could interchange nearly everything like you could on '36-'84 bikes.....)
Old Jul 8, 2018 | 01:03 PM
shanneba's Avatar
shanneba
Going back 10 years .....
Live to Ride Derby Cover - Part Number 25700472
https://www.harley-davidson.com/stor...04-25700472--1
2017 fitment-
  • Road King FLHR
  • Road King Special FLHRXS
  • Electra Glide Ultra Classic FLHTCU
  • Ultra Limited FLHTK
  • Ultra Limited Low FLHTKL
  • CVO Limited FLHTKSE
  • Street Glide FLHX
  • Street Glide Special FLHXS
  • CVO Street Glide FLHXSE
  • Road Glide Ultra FLTRU
  • Road Glide FLTRX
  • Road Glide Special FLTRXS
  • Tri Glide Ultra FLHTCUTG
  • Freewheeler FLRT
2007 fitment
  • Road King FLHR
  • Road King Classic FLHRC
  • Road King Custom FLHRS
  • CVO Road King FLHRSE3
  • Electra Glide Standard FLHT
  • Electra Glide Classic FLHTC
  • Ultra Classic Electra Glide FLHTCU
  • CVO Ultra Classic Electra Glide FLHTCUSE2
  • Street Glide FLHX
  • Road Glide FLTR
Old Jul 8, 2018 | 02:47 PM
Free Bird Too
6th Gear
Awesome info page! Thank you for the links shanneba!!
