Re-jet
Old May 2, 2008 | 10:14 AM
sportyc05's Avatar
sportyc05
Default Re-jet
Just finished installing big sucker stage 1 and rejetted with a 46 slow. Already had the shortshots on. Redialed idle and mixture and it runs great, got rid of the decel pop completely. Only problem is it quit on me once at a light when I cracked the throttle and I do get a slight kinda hesitation when I crack the throttle from idle. Only when in neutral, under load don't seem to get the hesitation. Any thoughts?
Old May 2, 2008 | 10:46 AM
Biker Trash's Avatar
Biker Trash
Default RE: Re-jet
What color are your spark plugs since the rejet? They should be off white to a light tan. Anything darker than that is too rich. you may only need a 45 "Pilot" jet.
Old May 2, 2008 | 10:57 AM
SportyPig's Avatar
SportyPig
Default RE: Re-jet
I was thinking the same as Biker Trash.
Old May 2, 2008 | 11:09 AM
sportyc05's Avatar
sportyc05
Default RE: Re-jet
Haven't looked yet. Had to take AC back off, an o-ring fell off during install and I didn't see it. Found it on floor when I came back. Instead of changing back to the 45, I'm out about 2.5 turns on the mixture, can I go in about 1/2 turn?
Old May 2, 2008 | 11:22 AM
cHarley's Avatar
cHarley
Default RE: Re-jet
I suggest you only adjust the mixture screw in 1/8 - 1/4 turn increments. It doesn't take much to make a difference.
Old May 2, 2008 | 11:23 AM
Biker Trash
Default RE: Re-jet
That is just the Idle mixture adjustment screw. Has nothing to do with much of anything else. Not sure what you piad for the #46 jet but I know the local indy charges $3.10 forjets here.It's an easy and cheap enough switch.
Old May 2, 2008 | 11:26 AM
SportyPig's Avatar
SportyPig
Default RE: Re-jet
Here are a couple of excellent articles, with pictures that cover re-jetting and carb tuning:
http://www.harley-performance.com/ha...arburetor.html
http://www.harley-performance.com/ha...r-jetting.html
Old May 2, 2008 | 11:33 AM
sportyc05's Avatar
sportyc05
Default RE: Re-jet
Yeah, that's what I paid for the 46 and I have the 45 that came out. I figured if leaning it a bit with the mixture would be a quicker fix. I'll ride it for about a half hour, check the plugs and go from there. Thanks guys.
Old May 2, 2008 | 02:10 PM
sportyc05's Avatar
sportyc05
Default RE: Re-jet
Went 1/8 in on the mixture and rode for about 40 minutes....no problems and the plugs look good.Maybe it just needed more running time and I rode it pretty hard.It's about 48 degrees and damp, let's see when it's 85 and humid.
Old May 2, 2008 | 04:27 PM
SportyPig's Avatar
SportyPig
Default RE: Re-jet
I re-tune my carb for each season. Cold dry air, and warm humid air doesn't combust the same way.
BiggCliff412
Carburetor Related
16
May 12, 2018 03:44 AM
RLJ676
Carburetor Related
18
May 4, 2011 09:08 PM
cmvsm
Mar 3, 2011 10:28 AM
Jip
Exhaust System Topics
May 4, 2007 10:36 AM
moreira72
Apr 6, 2007 08:49 AM
