Air Cleaner cover??
Old May 28, 2008 | 11:02 PM
BLLYGOAT's Avatar
BLLYGOAT
Default Air Cleaner cover??
Rather than spending more money and replacing my Air cleaner cover with a black one I was thinking of hitting it with some black High temp engine paint. Should work just fine right?
[IMG]local://upfiles/61645/FFD289E9FCCA46B3BE1EB28C03EB82C1.jpg[/IMG]
Old May 29, 2008 | 12:13 AM
Binny's Avatar
Binny
Default RE: Air Cleaner cover??
...........Yep....just take it off the bike first...just I little tech tip I thought of...B
Old May 29, 2008 | 12:17 AM
BLLYGOAT's Avatar
BLLYGOAT
Just wanted to make sure. Thanks and Yes I already pulled it off the bike. LOL
Old May 29, 2008 | 12:12 PM
ssbogger's Avatar
ssbogger
You might want to prep it a little first. I'm no paint pro but that doesn't look like bare metal you'll be spraying on. I have heard that a good paint job is all in the prep work.
Old May 29, 2008 | 12:19 PM
morton78's Avatar
morton78
I painted mine but I sprayed alittle primer first. I did not sand it down to bare metal because I wanted the texture that it had. I haven't had any problems yet and it has been almost a year.
Trae
Old May 29, 2008 | 01:15 PM
ecaldwell78's Avatar
ecaldwell78
Just scuff it with a scotch brite pad, clean off all residue w/ rubbing alcohol, prime, and paint. I don't know if it matters a whole lot but I make it a practice to not mix paint brands either. If I start w/ PPG, then I finish w/ PPG and not with DuPont. I am not knocking DuPont...it was just to illustrate my point.
Sash302
Nov 27, 2013 02:21 PM
chamba
Oct 24, 2011 10:18 AM
1sweetglide08
Jul 4, 2009 01:18 AM
Bradley Jones
Apr 2, 2008 08:55 PM
kylant
Oct 24, 2007 04:10 PM
